Old 09-03-2003, 05:46 PM
RobotGT's Avatar
RobotGT RobotGT is offline
SUPREME RULER
Tri cell mod
Here is my home maid tri cell mmod for y'all. Its fits best in Bb trucks with no bed cover.
Materials/Tools needed:
3 of the some type of Bit/Zip/MS batterys
Wire
Electrical tape
Soldering iron/pen/gun
Solder
something to remove a battery (EG:Smal screwdriver,guitar pick, and so on)
See link below for diagrams
http://pic7.picturetrail.com/VOL206/...4/30077300.jpg
Step 1: Solder a wire between the - end of cell 2 to the + end of cell 3
Step 2: Solder a wire to the + end of cell 2
Step 3: Solder a wire to the - end of cell 3
Step 4: Tape (or solder then cover with tape for extra hold) the wire from the + end of cell 2 to the - end of cell 1. Make shure the whole - end of cell 1 is covered with tape.
Step 5: Slide the cell 1 into the battery campartment CAREFULLY.
Step 6: Use a slim screwdriver or something real skinny and hard to push the wire coming off of the - end of cell 3 in between the tape and the - tab for the battery compartment.
Step 7: Modify your remote as mentioned here http://bitpimps.lixlink.com/pages/ar...?id=17&catId=1
Step 8: Drive liKE a maniac!
Oooh Khaaay there it is. If u have questions ill try to answer them.
full size zz wheels
Old 09-06-2003, 06:14 PM
wordlyfe wordlyfe is offline
y dun u try makin one so that the body can go on........like mybe putting two batteries on a wheelie bar or sumthin?
good job on da bit tho
my cars:
mazda rx-7-duel cell-lowered-dubs
skyline gt-r
supra
celica
lancer
Old 09-07-2003, 09:15 AM
TuRbO_GuY_69 TuRbO_GuY_69 is offline
Heres a great way 2 keep the batteries in side the shell:
http://www.rcmod.com/mod_internal.html
Old 09-24-2003, 06:18 PM
nxnitrous22 nxnitrous22 is offline
Send a message via AIM to nxnitrous22
what does a dual or tri cell mod do exactly. Like does it increase speed or torque, or does it just add run time?
Pennzoil GT-R (R-Spec II)- Front Tab Lowering, Rear Suspension Raising, Hard Tires, Green window tint
Loctite GT-R (2.8 motor)- Front Tab Lowering, Spring Coilover Suspension
Castrol GT-R (2.8 motor)- White Rims, Body Paint
American Hatchback Thing (1.8ish motor) - HEAVY body mods, metal roof cage
Old 09-25-2003, 04:53 PM
it depends on the way you connect it if its parrelal it will increase the runtime if its seris den it will make the dc motor go faster.............all dc motors go fast wen the voltage that goes to them increase.......oh by the way dont go higher than 3 batteries just to b on the safe side......cuz too much voltage can fry your pcb bord
my cars:
skyline gt-r
supra
celica
lancer
Old 09-25-2003, 05:22 PM
cool, thanks. So you thing if i ordered like the "150mAH NiMH Cell Battery" from the parts shop here at tinyrc.com, and hooked it up serial with my stock battery to a 4.2 motor, my car would like haul ass?
Tri cell mod. RobotGT Tips, Mods and Reviews 1 02-24-2010 05:27 AM
Just did the Tri cell mod but the run time sucks sporttracguy ZipZaps Monster Truck 8 02-10-2005 04:01 PM
The Layman's Dual Cell Mod (tm) actofgod Bit Science 207 02-16-2004 04:30 AM
Tri cell mod RobotGT Bit Char-G / MicroSizers 3 07-27-2003 12:06 PM
Dual cell mod ( will 2 - 50 mah's achieve + speed?) Suntzu28 ZipZaps 7 01-11-2003 10:57 AM
