Go Back   TinyRC.com > Tips, Mods and Reviews
Old 09-03-2003, 05:30 PM
RobotGT's Avatar
RobotGT RobotGT is offline
SUPREME RULER
Tri cell mod.
Ok y'all heres my home maid try cell mod.
Materials/Tools needed:
3 of the some type of Bit/Zip/MS batterys
Wire
Electrical tape
Soldering iron/pen/gun
Solder
something to remove a battery (EG:Smal screwdriver,guitar pick, and so on)
See link below for diagrams
http://pic7.picturetrail.com/VOL206/...4/30077300.jpg
Step 1: Solder a wire between the - end of cell 2 to the + end of cell 3
Step 2: Solder a wire to the + end of cell 2
Step 3: Solder a wire to the - end of cell 3
Step 4: Tape (or solder then cover with tape for extra hold) the wire from the + end of cell 2 to the - end of cell 1. Make shure the whole - end of cell 1 is covered with tape.
Step 5: Slide the cell 1 into the battery campartment CAREFULLY.
Step 6: Use a slim screwdriver or something real skinny and hard to push the wire coming off of the - end of cell 3 in between the tape and the - tab for the battery compartment.
Step 7: Modify your remote as mentioned here http://bitpimps.lixlink.com/pages/ar...?id=17&catId=1
Step 8: Drive liKE a maniac!
OK ABUYEBUYE
full size zz wheels
Old 02-24-2010, 05:27 AM
aldredheron
Great Trick.
thanks for sharing a trick tell me first it is not a danger and generate a any type of problem?
I tried the to see the the your diagram but it is not open and fire a error so check again the
link properly.
Just did the Tri cell mod but the run time sucks sporttracguy ZipZaps Monster Truck 8 02-10-2005 04:01 PM
The Layman's Dual Cell Mod (tm) actofgod Bit Science 207 02-16-2004 04:30 AM
Tri cell mod RobotGT Bit Char-G Mods and Projects 5 09-25-2003 05:22 PM
Tri cell mod RobotGT Bit Char-G / MicroSizers 3 07-27-2003 12:06 PM
Dual cell mod ( will 2 - 50 mah's achieve + speed?) Suntzu28 ZipZaps 7 01-11-2003 10:57 AM
