01-10-2003, 12:21 AM
Dual cell mod ( will 2 - 50 mah's achieve + speed?)
ZZ's come stock w/ 100 mah NIMH batts.
I want to perform a dual cell mod with 2 - 50 mah's ( i have extras laying around). Will the dual cell mod achieve the same speed results as it would w/ a dual cell mod using 100mah's? I would assume the only difference would be the run time... but i have never done a 2 cell mod.
Dual/Triple Cells Available
66 Pontiac GTO, Chevy S10, 69 Doge Charger, Hummer, Escalade, Acura Rsx Type S
01-10-2003, 11:28 AM
Hulk smash!
Voltage = Speed
mAH = Runtime
As long as you setup the 2 batteries in Series (Series = voltage adds together, so it would come out to 2.4v) then the dual pack will equate to higher speed.
01-10-2003, 07:11 PM
Namuna....last night i performed the dual battery mod in my ZZ using a parallel setup unwittingly. I now know this only increases run time at the sacrifice of speed ( extra battery weight). My question is ..when i set up the series diagram i would think the batteries would get hot / blow up. The reason i say this is because i hade a wire leading from the (+) contact on the chassis to the (-) contact on the 2nd battery. Then from the 2nd batteries (+) end a wire leading to the chassis (-) contact and the thing got MAD HOT.
The series set up seems to be exactly the same so what gives?
Is my series set up wrong?
(+) chassis contact w/ wire leading to (+) end of 1st battery
(-) end of 1st battery connected by wire to (+) end of 2nd battery
(-) end of 2nd battery connected to (-) chassis contact
01-10-2003, 08:18 PM
Bad Driver
Your batteries are probably shorted out. Check your insulation. Oh, and don't forget to mod your PCB for best results, this increases current to the motor while dual-cell increases voltage. both these are good.
01-10-2003, 08:34 PM
Race them naked
hi it seems you are having trouble "i read your post on the other boards" here is the dks diagram i used to do the dual batt mod it works great but the pic is for a bit so pay close attention to what you are doing and this should work for you it did for me http://www.driftkingshop.com/dualbatterymod.html
01-11-2003, 01:51 AM
Thanks a lot Sipsap . I finished the mod and it works well. The only problem is i cant get the Body on the chassis. Have ou performed a dual battery mod ( and if so how did you get the body back on the chassis)?
01-11-2003, 09:16 AM
Race them naked
very carefully i used the civic body and it was a very tight fit i also tried the porsch but it wasent going to happen but now i have done the pcb swap and the much smaller pcb lets you slap any body you want to on there
01-11-2003, 10:57 AM
Bad Driver
I just put some tape on my PCB cover and pushed it down. No muss, No fuss.
