Old 12-27-2002, 05:12 PM
omarjamil
Unhappy cat5 question(no better?)
hey, its pakiplaya here.
taken a break from anoying everyone lol.
changed my name so that i can start off fresh. i have a cat5 antenna. i couldnt solder it due to not having a soldering iron or gun.
i then cut the stock antenna in half, then cut off some insulation,
and took some insulation off the cat5 and then twisted both the copper wires from the stock antenna to the cat5.
i didnt get 1 inch differents in the range.!!
is this because it only works if u solder the cat5 alone? instead of twisting both different wires?
and i will keep my posting to new rooms lowered, thanx.
Old 12-27-2002, 05:42 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
cat5 wire made no difference to me. the only advantage is that you can pick the color of the antenna and the proper length.
Old 12-27-2002, 06:31 PM
omarjamil
yes, i got the same results. why do soo many people make such a big deal that they got so much more range? and what mhz are u using hogjowlz? and did u solder it to the board? or twist it to the stock antenna
Old 12-27-2002, 06:57 PM
hogjowlz's Avatar
i installed it on a 49mhz and soldered it straight to the board. it didnt hurt the range but it didnt help. plus i got to pick the color of the antenna. whooopty doo.
Old 12-27-2002, 10:55 PM
shocon2k
22 guage solid copper wire.
nuff said
Old 01-14-2003, 09:33 PM
masterjin
i dont get it? 22 gouge copper wire? so what does that mean
Old 01-14-2003, 09:55 PM
sessiz10's Avatar
sessiz10 sessiz10 is offline
Told ya.
Exactly what he said.
____________________
Meh.
Wondering About Some Cat5 Speedking221 ZipZaps SE 2 09-18-2004 05:46 PM
Complete 1st mod, Cat5..... DarkTari Bit Char-G / MicroSizers 15 01-29-2003 06:01 PM
cat5 antenna for internal wiring 8ate8 Bit Char-G / MicroSizers 5 12-26-2002 05:59 PM
Cat5 vs Cat5E for car antenna material mechanist ZipZaps 6 10-13-2002 01:59 AM
commercial grade cat5?? bojangs Bit Char-G / MicroSizers 2 09-30-2002 02:23 AM
