Old 12-25-2002, 10:24 PM
8ate8 8ate8 is offline
Send a message via AIM to 8ate8
cat5 antenna for internal wiring
would it be OK to use the CAT5 antenna for internal wiring in my controller? i've snapped the battery --> PCB and PCB --> charger wires too many times. and the CAT5 stuff is thicker. much thicker. would it be OK to use that to replace those wires, or is CAT5 meant more for data transmission (network cables, or as in this case, radio frequencies via the antenna)?
Old 12-25-2002, 11:17 PM
DavidDeLaurier DavidDeLaurier is offline
Send a message via AIM to DavidDeLaurier
I have had the same problem. I may do it to my remote tonight...
Old 12-25-2002, 11:37 PM
1llusI0n 1llusI0n is offline
BitOnline GM
Send a message via AIM to 1llusI0n
i dont think it would realy do anything at all wire is wire. But anyone else correct me if im wrong
My Car
White BCG Skyline 27mhz 3.0
Yellow LXX Skyline 03mhz 3.0
Charg and Go 27mhz 2.6
Cannon 49mhz 2.2
Old 12-26-2002, 04:34 AM
guy121 guy121 is offline
Wire is wire. Bigger wire does help a very minute amount by having a lower voltage drop.... but there's barely any to even notice in the first place. So yeah, go ahead.
Old 12-26-2002, 04:49 PM
i'm not doing it for better voltage transfer. i'm doing it cuz i keep snapping the wires that are there and the cat5 is much thicker, so it won't snap as easily..
anyways, i replace the wire in there with cat5 and it works fine..
Old 12-26-2002, 04:59 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
like he said above wire is wire. cat5 is pretty good wire. i installed it as an antenna and i think i gained a whopping 6 inches!!!
need a new TX antenna? TypeZer0 XMODS Parts and Hop-Ups 3 02-15-2004 07:09 AM
Alternate antenna ideas! caver01 Bit Science 214 11-07-2003 09:38 PM
where to buy the cat5 antenna? CARFREAK Bit Char-G Mods and Projects 6 12-05-2002 10:11 PM
question re: dual cat5 antenna ejaf ZipZaps 4 11-26-2002 03:29 PM
Cat5 vs Cat5E for car antenna material mechanist ZipZaps 6 10-13-2002 12:59 AM
