Old 01-04-2004, 09:38 PM
e9d6w7a9r2d's Avatar
e9d6w7a9r2d e9d6w7a9r2d is offline
Send a message via AIM to e9d6w7a9r2d
Question Plastic Heat Sink
Can i use the plastic heat sink on the stage two motors? or will it melt?
Old 01-04-2004, 11:39 PM
tavisjohn's Avatar
tavisjohn tavisjohn is offline
RC Tinkerer
The "Plastic Heatsinc" that comes in the car is not really a heatsink, it is just a motor mount. You really need the Stage2 Heatsink in order to use a Stage2 motor. (I even use the Stage2 Heatsink on my Stage1 Motors)
Old 01-06-2004, 08:40 PM
Martlet21 Martlet21 is offline
Send a message via AIM to Martlet21
You don't need the metal heat sink at all. If you're really concerned with the weight of your car, you can just use plastic motor mount and run for shorter amounts of time and take longer breaks to let the motor cool.
My Tiny R/C:
XMODS Yellow Skyline GT-R
AWD
Jumbo Tires
Stock everything else
Old 01-06-2004, 10:00 PM
hoopsta1423 hoopsta1423 is offline
the only time i would use the heatsink is if u have 5 or 6 cell mod, driving for like 10 mins makes the motor really hot, but u really dont even need the heatsink
Old 01-07-2004, 12:25 AM
so if i add a stage 2 motor and using the plastic motor mount, it won't melt if i let it cool and give it short runs?
Old 01-07-2004, 05:58 AM
Joey's Avatar
Joey Joey is offline
There probably isn't a fan both light and energy-efficient enough to be worth installing to cool the motor off. I don't think you'd melt the plastic mount even if you ran it for the life of the batteries, but you wouldn't want to do that very often, just in case. Using the stage 2 sink is just a better idea, I don't see why you'd want a plastic one in the first place.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
Old 01-07-2004, 10:26 AM
tavisjohn's Avatar
RC Tinkerer
Originally posted by Vagabond
i remember someone installed a micro fan to the motor to cool things down. What are the suitable fan to do the job? And what's the amp draw?
I remember a discussion about installing a fan, however I do not think anyone actually installed a fan.
Old 01-07-2004, 06:04 PM
spitty12's Avatar
spitty12 spitty12 is offline
Happiness is a warm gun..
Send a message via AIM to spitty12
I've heard of a guy using a 5cm x 5cm computer fan but I think it would be a waste considering the weight and current draw.
I used a dremel and an exacto knife to cut out the vents in the body work. I have a white body so the bare plastic isn't very noticeable but i'm going to be painting it soon any way.
Old 01-07-2004, 08:47 PM
Joey's Avatar
It's not connected to anything at the moment, but what it's going to be connected to is either too heavy for the amount of power it provides to make the tradeoff, or it's connected to the XMODS batteries, robbing the motor of power enough to heat it up in the first place and negating the whole point of the fan.
It's just not that big a deal; people run six-cell mods with hot motors all the time, and they don't blow.
Mazda Savanna RX-7
Old 01-08-2004, 01:36 AM
spinitsidewayz!'s Avatar
spinitsidewayz! spinitsidewayz! is offline
boro dori style RC
about that fan idea,
if you could, you mught be able to mount one directly to the front of the motor if you extended the armature shaft? just attach a little fan and the motor would spin it.
true looking aluminium heat sink rydzjunior XMODS 0 01-03-2007 09:40 PM
heat sink questions AE86 Toyota XMODS 3 07-31-2006 01:11 PM
FET Heat sink shorting with ESC Horshu XMODS 2 03-30-2005 08:23 AM
Heat sink source Tee Bee XMODS 2 11-03-2003 06:27 PM
Heat Sink??? STFU Tuning XMODS 15 10-23-2003 05:47 PM
