Old 12-29-2003, 03:00 PM
shane-o shane-o is offline
Send a message via AIM to shane-o Send a message via Yahoo to shane-o
Angry screw screws!!!!
whats with these xmod screws!!! I JUST BOUGHT a new white supra (my third xmod) brand frikken new... went to replace the stage1 with my stage2 drift... and i frikken stripped a screw on the bottom (one of the flat screws)
the real head banger here is... I cannot replace the rear end of the supra because of one frikken screw. i would like to put my bearings for the rear axle and such too...
any methods of removing this menacing screw? please advise...
Old 12-29-2003, 03:15 PM
chrishidalgo chrishidalgo is offline
Send a message via AIM to chrishidalgo
i dont know if you tryed this but try a little bit bigger skrewdriver, i NEVER use the rs one
skyline
stage 2 motor upgrade(yellow)
IC-3's
Old 12-29-2003, 03:22 PM
i tried that too... the damn thing stripped waaaaaaaaaaay too easily... i mean... brand new car... new screw driver... and wham... stripped... i dont want to take it back for just a stripped screw! lol
Old 12-29-2003, 03:45 PM
Daazndood Daazndood is offline
i hate those screws!!!! the screws on the arms that hold the axle and suspension are very bad. i have to use pliers every time i take it out or screw it in. i hope radio shack sells like a pack of screws that you need for the xmods that are better quality.
Old 12-29-2003, 03:56 PM
titanium screws would be flippin awesome
Quick!!! look ahead! see that!?!?! ITS MY DUST!!! BWWWAHHHH AAAAAH HAAAAAA
Old 12-29-2003, 05:26 PM
maby home depot might have some little skrews
skyline
IC-3's
Old 12-29-2003, 05:46 PM
97PrizmLsi 97PrizmLsi is offline
As for your question: Get a small needlenose pliers. Grip the screw firmly and begin to loosen..this is what I do with screws that are too far gone.
I have stripped too many Xmod screws in my day, and I have only had it for about a week...Definitely switch screw drivers (I have 4 different Craftsman screwdrivers that I use for each type of screw). You can use a regular screw in the place of the flat body screw, it doesn't make a difference. Whenever you start stripping a screw if you get it out then throw it away and just replace it with a new one. With upgrades and extra screws you obtain you can just replace it and save yourself the hassle. I have too many screws to count.
Old 12-29-2003, 10:11 PM
Hairball Hairball is offline
Cheese Ninja
Send a message via AIM to Hairball
I use a Swiss Army knife for the stripped screws.... The tip of the blade really bites into whats left of the head.
ThisonetimeIwaslostinthewoodsandIsawthisguywhohada steakandIwaslikewhoa.
Old 12-30-2003, 09:03 AM
thanks alot fellas... i just ended up cutting the thing down...and popped out the screw... worked out nicely!
Old 12-31-2003, 12:07 PM
neurokinetik's Avatar
Mad Scientist
True that... there's nothing wrong with the screws, it's the crappy screwdriver that RS includes. I've never used them, so I've never had a problem.
Old 01-01-2004, 09:00 PM
Shiporu's Avatar
Shiporu Shiporu is offline
I make great sandwiches
Send a message via AIM to Shiporu Send a message via Yahoo to Shiporu
i used the screw diver that i got from Sunglass hut....too short though.... but it does grip good and did not strip the screws once... but rs driver ate up my screws....
My Xmod:
now has Tiny Rc parts and schools everyone here!!!
Old 01-02-2004, 12:39 AM
suprafreak33 suprafreak33 is offline
got supra?
same here so i just get the tool kit works great!
xmod
blue supra
6 cell
all upgrades[by rs]
Old 01-03-2004, 12:13 AM
Rx7NoZ's Avatar
Rx7NoZ Rx7NoZ is offline
go to xmodrc.com they sell 10 screws for 1 dollar not xmodsrc.com xmodrc.com
Xmod:
Civic (black)
Stiff Suspension
Awd
White side skirts,White Carbon fiber hood,White rims and Drop
Old 01-03-2004, 12:15 AM
Revlis Revlis is offline
Now I just use an electric drill w/ a screw bit in it.. it's alot harder to strip the screws and it allows you to remove some of the screws that have been stripped
Old 01-05-2004, 10:19 AM
Blackhawk Blackhawk is offline
Send a message via AIM to Blackhawk
Re: screw screws!!!!
dremel.
-Toyota Supra
-AWD
-med springs in front
-stiff springs in rear
-4.5 tie rod
-wheel upgrade:
1. racing set (soft treads)
2. drifting set (hard slicks in rear, hard treads in front)
-metal bearings
-top secret motor
-IC-3 batteries
size of screw for gpm steering knuckles? Clint XMODS Parts and Hop-Ups 4 07-02-2005 05:40 AM
60 Second motor swap w/ stage 2 (5 screws!) ax0n XMODS Parts and Hop-Ups 2 12-30-2003 01:59 PM
tip to keep the screw on the screwdriver security civic XMODS Parts and Hop-Ups 14 12-12-2003 11:11 PM
Antenna screw Hugopolo XMODS 2 11-28-2003 07:03 PM
Loose Screw or two or three DAMZer ABC DTM Parts and Hop-Ups 0 05-10-2002 10:55 PM
