Go Back   TinyRC.com > 1/24 and Smaller > ABC DTM > ABC DTM Parts and Hop-Ups
Old 05-10-2002, 10:55 PM
DAMZer's Avatar
DAMZer DAMZer is offline
Loose Screw or two or three
The kit goes together easily but one thing I found out after a few runs, the one screw that you can't get to easily is the one that comes loose.
Sometimes you get in a hurry and forget the basics......Always use theadloc on metal to metal screw coneections!!
The screw that holds the center damper post to the chassis came loose, but not out. You have to damn near dis-assemble the whole rear top components to get to this little screw. You will also need to use threadloc on the kingpins and rear motor pod assembly.
screw screws!!!! shane-o XMODS Parts and Hop-Ups 14 01-05-2004 10:19 AM
tip to keep the screw on the screwdriver security civic XMODS Parts and Hop-Ups 14 12-12-2003 11:11 PM
Antenna screw Hugopolo XMODS 2 11-28-2003 07:03 PM
Loose Treads? Strider Combat Digi Q 2 04-14-2003 05:49 PM
Screw Socket: DTM SP was ist los? ABC DTM SP 1 02-08-2003 06:48 PM
