Old 12-04-2002, 12:09 AM
HO502cid's Avatar
HO502cid HO502cid is offline
Send a message via ICQ to HO502cid
Question regarding charging.
When I place my MicroSizer onto the controller for a charge the light turns on for a couple seconds and then turns off. The battery in the car is completely depleted at this point so it is obviously not fully charged. After I remove the car from the transmitter and place it back on it will take a full charge. Do you have any ideas what might be causing this or is it normal?
--Thanks in advance!
Old 12-04-2002, 01:50 AM
Blue Bit's Avatar
Blue Bit Blue Bit is offline
Toy Collector
that happens occasionally to a couple of my bits, but i did not pay too much attention to it. I was assuming I did not place the chassis in the charger properly the first time and the contacts did not have a clean connection. But it could be other things though.
Old 12-04-2002, 03:23 AM
alpha1's Avatar
alpha1 alpha1 is offline
Runs with sharp stuff
When you go to charge your car, make sure that you turn on the charger first before you put the car on.
layman's tricell charging question Snow Bit Char-G Mods and Projects 0 11-28-2003 06:06 PM
Another Charging Question Buzzbait Epoch RC1/43 2 05-03-2003 02:17 AM
Semi-technical charging question extremeR1der Bit Char-G / MicroSizers 6 04-30-2003 11:36 AM
electrical question about charging..resistor values..limiting current.etc Clint Bit Char-G / MicroSizers 17 03-07-2003 02:49 PM
Battery charging question rmelancon Epoch RC1/43 2 12-19-2002 11:52 AM
