Old 12-19-2002, 09:50 AM
rmelancon
Battery charging question
The epoch battery pack is a 120mah pack and the transformer for the charger charges the cells at around 750ma and shuts off at 180 seconds (3 minutes). Doing the math using
Charge Current( in milliamps) X Charge Time (in hours) =capacity in mAh
gives only 37.5mah
So why is the charger cutting off after only charging about 1/3rd of the packs capacity? Granted unless the car is completely discharged you won't have 120mah to charge but I would think that after running to the point where there isn't enough torque to give any forward movement you would have used more than just 1/3rd of the capacity.
Any ideas?
Old 12-19-2002, 10:33 AM
e_lm_70 e_lm_70 is offline
Are U sure the charger just do 750mA ?
Old 12-19-2002, 11:52 AM
rmelancon
I put an ampmeter in series with the circuit during a charge and that's what it read. The 9V 500ma rating is not very accurate when you actually hook it up to a digital multimeter. Voltage is actually 14V and like I said the amperage is around 750 during a charge cycle.
Another Charging Question Buzzbait Epoch RC1/43 2 05-03-2003 02:17 AM
electrical question about charging..resistor values..limiting current.etc Clint Bit Char-G / MicroSizers 17 03-07-2003 02:49 PM
FYI:Motor Works (clone) charging base will charge dual and triple battery setups. Clint Bit Char-G / MicroSizers 0 02-17-2003 04:09 PM
More powerful steering for 2-cell mod? bonus: faster charging for dual battery mod Chris Bit Char-G Mods and Projects 1 11-23-2002 07:24 PM
