Old 05-01-2003, 09:09 PM
Buzzbait's Avatar
Buzzbait Buzzbait is offline
Another Charging Question
I just got my Epoch, and love it. I’ll post more on the Epoch later. I just have a quick charging question for the battery gurus. I was pretty bummed out with the Epoch AC adapter that I bought. It’s a 9volt, 1.2 amp adapter. That’s right. They are now shipping 1.2amp adapters. So I scrounged around the house, and found a perfect 9volt, 350mah AC adapter for the charging base. I’m just not quite sure how long of a sustained charge I can do on the batteries at this level of current. My calculations suggest that I can do a 24 minute charge to fully charge the cells, but I’m not sure about the heat issue. Do you think that 24 minute charging sessions would be okay, until I can pick up a peak charger, or would I cook the batteries?
Old 05-01-2003, 11:59 PM
chelboed's Avatar
chelboed chelboed is offline
Epoch's R Bett'R
At 9v, that's a bit too long. I would only go about 8 minutes at the most. If you want to chg. longer, get a 6v cord.
Old 05-03-2003, 02:17 AM
blind's Avatar
blind blind is offline
None Better
I just chopped the cord off the charging base and hooked it up to my peak charger...
I do believe a Great Planes Triton has no problems detecting the peak
layman's tricell charging question Snow Bit Char-G Mods and Projects 0 11-28-2003 06:06 PM
Semi-technical charging question extremeR1der Bit Char-G / MicroSizers 6 04-30-2003 11:36 AM
electrical question about charging..resistor values..limiting current.etc Clint Bit Char-G / MicroSizers 17 03-07-2003 02:49 PM
Question about charging. Nefarious Bit Char-G / MicroSizers 6 02-06-2003 08:04 AM
Battery charging question rmelancon Epoch RC1/43 2 12-19-2002 11:52 AM
