Go Back   TinyRC.com > 1/24 and Smaller > Dynamite Rocket Racer > Dynamite Rocket Racer
Old 02-24-2003, 11:49 AM
misterbungle misterbungle is offline
Send a message via Yahoo to misterbungle
slipper clutch
Anyone know the correct or desired setting on the slipper clutch on these things? Mine seems too loose and I don't think i'm getting all the traction I can. Any thoughts?
Old 02-24-2003, 02:41 PM
fastboy fastboy is offline
im a micro daddy...
Send a message via Yahoo to fastboy
there is no slipper on the rocketracer..if you mean the differential then there should be no slip whatsoever..if you let the diff slip you will damage the diff plates and diff balls and run a risk of overheating the diff plates and melting the spur gear..you have been warned
if the diff is fully tightend and you still getting slip then you could place a small washer between the small silicon diff ring and the diff, make sure its hole is big enough to go onto the shaft.
this has the effect of putting more pressure on the diff plates.
dave
uk
Plz Look!! Slipper And Or Tranny Question! lilrichie1306 Micro-T General 3 01-24-2008 03:22 AM
Clutch? civic freak XMODS Mods and Projects 4 07-04-2004 01:52 PM
clutch lsd lankyj XMODS 2 02-08-2004 02:01 PM
paper clutch LSD!! spinitsidewayz! XMODS Mods and Projects 22 02-07-2004 11:00 PM
engaging and disengaging clutch stuff.. cowfish_29 Bit Science 19 01-29-2003 08:29 PM
