Go Back   TinyRC.com > 1/36 and Smaller > Losi Micro-T / Desert Truck / HIGH Roller > Micro-T General
Old 07-16-2007, 05:14 PM
lilrichie1306 lilrichie1306 is offline
Plz Look!! Slipper And Or Tranny Question!
Ok this is my first question that ive had concerning my micro t..... its all stock with ball bearings only, and i was driving it around when i noticed that the speed had dropped a tad bit, and that on carpet it turned hard to the right... so i took off the wheels to find a ball of hair stuffed around the axle near the bearing and wheel, preventing that side from turning...... so only one of the axles were turning, and it was turning at a tad bit higher rate of speed than normal.... so my question is, its all fixed now, running fine, but did that possibly wear down the slipper pad and or tranny gears at all???? i need to know scince im ordering some other parts for my Rusty, and if that lil problem wore down the slipper pads or screwed up the tranny at all, i need to know NOW. like i said, i prob ran it for a half a run like this till i picked it up and saw that only one axle was spinning due to the hair or carpet fuzz rapped around my other axle... i wouldnt think that it would have screwed either of the two up.... but im just makin sure lol
PS its running fine, i just need to know if a new slipper would be beneficial
Old 11-17-2007, 01:29 AM
cory b cory b is offline
man, its pretty hard to tear up the slipper.the differential took gears took the abuse there. pick the car up and spin one rear wheel.the other wheel should go the opposite direction. also, when you spin them there shouldnt be much resistance,or any crunching or drag feeling. its probably just fine, you can do this and that will tell you if anything is messed up.
Old 01-22-2008, 08:32 PM
rider66441's Avatar
rider66441 rider66441 is offline
my micro-t does the same thing even when it doesnt have anything rapped around it. what would cause that?
Old 01-24-2008, 02:22 AM
hopperguy hopperguy is offline
you aint gonna get no info or replies here.. they skip right over the micro's
http://micromodz.all-up.com/portal.htm
