Today after I installed my new black rims set, a new motor, and rare earth magnet on my Bit Char-g my steering stopped functioning properly. The magnet still responds, but when the front end is completely assembled the most I can get from the steering is a very minute twitch. The motor responds perfectly, everything is fine except for the steering.
I have double checked all the wiring and connections and everything seems proper, and like I stated earlier the magnet still responds. I've tried using the original stock parts with the front end, axles and all. Same results, a barely noticeable twitch.
What the hell is going on? I have no idea what to do next, any help will be more than welcomed
And I will supply any pictures if needed, thanks again.
Andrew
PS - If it makes a difference I removed the sway bar some time ago, but even then the steering still worked perfectly prior to today's "upgrades."
