Old 01-31-2003, 07:03 AM
noxorc
Show me the Governor!
My Microsizer has terrible range.
Could be the Car, could be the Remote.
I have seen other pictures with a registor as the governor, and when removed has given better range.
I don't see that, or others I have seen, on my remote.
Any help?
Old 01-31-2003, 07:13 AM
shanly
you could remove the crippler capaciter in the remote... go to www.questformadness.com , they will show you how to do it
Old 01-31-2003, 07:17 AM
Dorifto! Dorifto! is offline
Drift!
I think you are reffering to a cripple capaciter. If you dont see one on the controller, maybe you have one on the car itself. I had this on my microsizer sport and after I removed it I had great range.
All your base are belong to us!
Old 01-31-2003, 07:44 AM
shanly
i also removed the cripple capicot in my car as well, i DID notice notice a change, the remote is what really helped was the remote mod...
Old 01-31-2003, 09:11 AM
noxorc
Did the mod
I removed the resistor. No difference, at lease nothing obvious.
-Nox
Old 01-31-2003, 09:43 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
im telling you. a 3rd battery in series in the controller will double your range. in combo with a larger antenna you will notice a big increase. or you can rip things off your circuit board or hope that using neat-o orange wire will magically give you 50foot range.
Old 01-31-2003, 03:09 PM
shocon2k
Whats that black box with the ribbon wire coming out of the bottom of your remote?
Old 01-31-2003, 05:15 PM
jei$'s Avatar
jei$ jei$ is offline
hey WTF
is that big black box with blue wires stickin out of it?
A man who desired nothing is invincible.
Old 01-31-2003, 05:20 PM
redemption's Avatar
redemption redemption is offline
Send a message via AIM to redemption Send a message via Yahoo to redemption
I think...that If i read his earlier posts correctly...
it attaches to his serial port (i think) so it can be controlled by his computer...
i think
Old 01-31-2003, 08:18 PM
t-squared's Avatar
t-squared t-squared is offline
Bit Obessed...
earlier post?
http://www.tinyrc.com/forums/showthr...&threadid=6410
Old 01-31-2003, 08:46 PM
shanly
Old 01-31-2003, 09:22 PM
Hatchet_Dan's Avatar
Hatchet_Dan Hatchet_Dan is offline
Juggalo Bit Drag Racer
Send a message via AIM to Hatchet_Dan
Show me the Governor! Show me the Governor!
heh i had to do it
Old 01-31-2003, 10:21 PM
redemption's Avatar
Originally posted by t-squared
earlier post?
yeah...that one
Old 01-31-2003, 11:06 PM
Pojo's Avatar
Pojo Pojo is offline
Corolla Power!
EDIT 1 : YEA!!! My 500th Post!
EDIT 2: For Nox, if any of the info in this post fails, try www.questformadness.com
Hmm, it doesn't appear that you have a cripple capacitator on your controller, but here's a list of stuff you can try instead :
1. Undo the antenna knot under the car's PCB.
2. Install brand *spankin* new batteries in the remote, or do the triple-battery controller mod like hog suggested. Note-I'm not sure how to do this, but I'm sure a l33t electronics d00d like you can pull it off.
3. Install a telescopic antenna from RS on your car's remote.
4. Buy some 22awg or higher solid copper cable from RS, and use a bit for a new antenna for your car.
5. Hold the darn thing over your head?
6. Have I run out of ideas?
Well, if none of these suggestions work, and you're abolutely sure that the cripple cap removal on the car did nothing for range, than I suggest you re-solder in the car's crip cap. It will at least help to block out interference from other Bit frequencies. I say this because after removal of my Hiroto's car crip cap, I noticed my 27mhz controller was able to control the 57mhz car. Alas, it's quirks like those that make these little guys so dang fun!
show off your moded cars and pics of ur racing track show off, learn, help whatever guitarplaya3000 ZipZaps Mods and Projects 1 12-23-2005 01:20 AM
Does anyone on this website street race or do they have a show car freakanoid 1:1 Scale Cars 70 06-23-2005 10:07 PM
New York International Auto Show GerG 1:1 Scale Cars 2 06-23-2004 12:23 PM
RC Hobbies Show on DIY Network BillyBonz Bit Char-G / MicroSizers 3 09-13-2002 04:51 PM
Our new Micro-track to debut at Chicago International Hobby Show lornecherry Bit Char-G / MicroSizers 14 08-14-2002 04:52 PM
