Old 01-27-2003, 10:08 PM
sS. Nomad sS. Nomad is offline
Advice & Suggestions : 350Z The Works
Alright im new to this Micro R/C stuff so ima need some advice, I plan to get a 350z micro r/c, i want it to be real fast, i want a booster on it, im not sure if it comes with one, i was wondering if the 350z comes with the controller needed for the boosting, i was also wondering, im guessing the 350z comes in 2.2 with booster, is there a way to get a 3.8 engine with a booster? im a major newb so if ya could give me some tips on it.
P.S do they sell that 350z w/ booster with the Controller on tinyrc.com?
Old 01-27-2003, 10:38 PM
shocon2k
Yes u are a noob, hehe.
Anyway, you can put any motor u want in a car, booster or not. And I believe the 350z aka Fairlady is a booster car. However these are hard to find in the states.
Old 01-27-2003, 11:20 PM
jei$'s Avatar
jei$ jei$ is offline
noob sS
u cant buy cars modded 4 ur delight here
i think the shop on thhis site only has MS
yes u can interchange the motorbut u hab 2 buy it
seperately it does come with a booster
and boost button control aiite?
is fa sho
A man who desired nothing is invincible.
Old 01-28-2003, 06:15 PM
so the fairlady comes with a booster? and a controller right? i believe the engine is 2.2 w/ booster can i change that 2.2 out with a 3.8 and still have the booster?
Old 01-28-2003, 06:22 PM
dabigpig's Avatar
dabigpig dabigpig is offline
it doesn't matter what motor you have in it because when your car is unboosted (not hitting the boost button) the car is pulsing power to the motor causing it to go about half speed. when you push the boost button the pulsing stops and you get a full signal of power to the motor causing it go go fast. the car will send a pulsing of power to the motor with any motor whether it's a 1.0 or a 3.0.
HTH
instead of the pulsing it may also have a resistor but from what i have heard i think it pulses
P.S.
corect me if someone is more experienced than me.
*** AMC Veteran ***
-- ^-_-^
Need suggestions & volunteers for "How To's". Bad Company XMODS 35 06-04-2007 05:38 PM
ive noticed more then just shrink tubeing on my 350z.... strtrcril87 XMODS 30 07-31-2004 10:45 PM
Covertable 350Z project. Bad Company ZipZaps Gallery 44 01-10-2004 10:18 PM
FYI:Motor Works (clone) charging base will charge dual and triple battery setups. Clint Bit Char-G / MicroSizers 0 02-17-2003 05:09 PM
Bit 350z has 2 foot range? blind Bit Char-G / MicroSizers 22 11-30-2002 03:59 PM
