Old 02-17-2003, 05:09 PM
Clint Clint is offline
Wide Open Throttle
FYI:Motor Works (clone) charging base will charge dual and triple battery setups.
the motor works charging base charges with 4.5volts stock and uses 3 AAA batteries. This is absolutly perfect for charging a dual battery zip zap or bit.
i modified the motor works charger and attached a zipzap charging clip and
packaged it within the zip zap controller cover.
with 4.5v and a little extra current from an external power source it'll charge my 3 battery bitzap. i modified the motor works charger and attached a radio shack mini dc adapter 4.5v 1600mA. I also use a 3v-12v 800mA adjustable power adapter...both work fine.
for a dual setup with 150mA batts..charge 2.5 times..3 gets a little warm
for a triple batt setup charge 3 times...4 if u can wait that long.
i havent tried running 6v thru the motor works charger..but there doesnt seem to
be anything that would fry...the cap gets warm..but that's just the cap for the timer. easily upgraeable.
go to this post (in gallery) for more pics.
http://www.tinyrc.com/forums/showthr...&threadid=8454
Build a Stand-Alone AC (or battery) charger SuperFly Tips, Mods and Reviews 0 09-03-2003 08:22 PM
