Old 12-22-2002, 10:29 PM
kmvargo kmvargo is offline
Lightbulb Steering Magnet Coil Wires
I have read here a couple of times about people breaking and trying to repair the wire that go from the PCB to the steering magnet coil. I found several years ago a couple of spools of wire used for wire wrapping PCBs. It is used when you are making custom PCBs. The wire is very thin with a thin coating. You will have to go to a really good electronic supply store to find it (I don't think RS carries this). It will be delicate work but ir probably will be better then what is in your car now and you can make the wires longer so you can work on the battery compartment easier.
Here is a picture of the spools of wire that I am talking about ...
I am wondering if this could also be used to make the steering springs. I have not taking a steering assemble apart yet so I am not sure.
* Vintage GIJoe Collector *
* Micro RC Collector *
BTCG - Lancer EVO 27MHz & Honda S2000 45MHz
MS - Subaru Impreza 27MHz, Mazda RX-7 27MHz, Honda S2000 27MHz, Nissan Skyline 49MHz, Mitsubishi Lancer 49MHz & Honda S2000 Sport (Purple) 49MHz
LXX - Skyline Xaniavi 57MHz, Skyline Castrol 35MHz, Skyline Pennzoil 45MHz & Skyline Loctite 27MHz
ZipZap - Mustang 27MHz & Civic 49MHz
TTHongli - Celica 27MHz
MB - Spider - 27MHz
3 MW - Various Models - (1)27MHz & (2)49MHz
3 Generic - (1)49MHz & (2)40MHz
Precious - Mazda RX-7 - 27MHz
4 Micro - ZXR1 Racers (2)27MHz & (2)49MHz
BTCA - Accord Wagon - 35MHz
4 Huale cars - 35MHz & (3)45MHz
Mini Cooper iRacer by Nikko
Old 02-13-2003, 04:22 AM
scottyboyfun's Avatar
scottyboyfun scottyboyfun is offline
Im a cat, miow.
Send a message via Yahoo to scottyboyfun
You need thin enamelled wire for making the steering coils, check out my guide, it'll really help!
http://tinyrc.com/forums/showthread....&threadid=8242
I cant tell how thin the wire is in the pic, so im not sure, if its a similar thickness to that already in the cars, then go 4 it!
Try electronics stores otherwise.
So what do u lot think?
Post it!
Extending steering coil wires? atvpsycho ZipZaps 3 08-15-2003 11:41 AM
Single/Multi coil steering columns cm961 Bit Char-G / MicroSizers 4 07-28-2003 10:59 PM
resoldering steering coil wires to pcb jedclampit Bit Char-G Mods and Projects 2 03-22-2003 07:49 PM
Microsizer Steering Magnet chelboed Bit Char-G / MicroSizers 6 02-13-2003 04:14 AM
