Old 12-02-2002, 11:18 PM
t_dawg
Angry crapy 3.0 motors
I just got a new 3.0 motor in the mail and there is only only 1 probolem with it, it only goes forward and not backwards on the groud. but when i hold it in the air it seems to go perfect forward and backward, but when i put it down it craps out.
Is there any thing i can do with out taking the engine apart.
id like to here your sujestions!!!!!!!!!!
Old 12-02-2002, 11:20 PM
Acceptable_Risk Acceptable_Risk is offline
Are you using it in a Tomy car or a clone? Some of the clones have problems with the faster motors.
Old 12-02-2002, 11:24 PM
t_dawg
Im using a clone. and is there any thing else i can do
Old 12-02-2002, 11:42 PM
I'm not sure. I don't have any clones. Sit on the topic for a bit. There's probably someone around here who knows.
Old 12-02-2002, 11:45 PM
t_dawg
ok thanks
Old 12-03-2002, 04:32 AM
alpha1's Avatar
alpha1 alpha1 is offline
Runs with sharp stuff
You may want to try and adjust the position of the motor in your clone. Try to make sure that the tab is aligned properly to the one on the motor. It seems that some clones are very sensitive to that.
Old 12-03-2002, 09:11 AM
maximahp
Also if you can, try different sets of gear ratio's. Some of my cars wont run the greatest with taller gears. But again the motor mount plays a big roll.
Pojo's Avatar
Pojo Pojo is offline
Corolla Power!
well tyler I think you should buy an OFFICIAL CAR! hahahaha
Old 12-03-2002, 10:34 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
ive dealt with this.
and ya it seems to be the little connection on the back of the motor not hitting the connector in the car. try putting a tiny drop of solder on the connection on the battery. tomy motors are shorter than most of the clone motors i have bought. i had my buddy put solder on two that i was havin trouble with and now i have no troubles with them except for the fact that they should be even faster. heh
hogjowlz's Avatar
oh ya. you can break the solder off if you dont like the results.
Old 12-03-2002, 10:47 AM
SAM SAM is offline
Have fun at any age
I run 3.0 and 3.4 in my clones with no problems at all.You do have to look at the tabs like others have stated......
MQ--911 GT3 fullsize wheel mod,cat5,3.8,front springs
MS--WRX fullsize wheel mod,cat5,3.8,front springs
Zip Zap-Civic slammed,no reverse,cat5,NOS
Lxx 3.0 motor vs Bit Char-G motors bill Bit Char-G Parts and Hop-Ups 36 12-26-2002 07:53 AM
Lxx 3.0 motor vs Bit Char-G motors bill Bit Char-G / MicroSizers 3 12-06-2002 09:47 AM
Do the 2.6 and 3.0 motors burn out at all?? Mellow Yellow Bit Char-G / MicroSizers 5 09-22-2002 12:09 AM
Different Grades of 3.0 motors burningtea Bit Char-G / MicroSizers 2 09-20-2002 02:50 PM
