Old 11-21-2002, 03:46 AM
usagi20
350Z Donuts
Hey guys, I just got the 350Z and a booster 4 ch. controller, a 2.6 motor, and #2 strut. Man, the thing is fast the problem is I just keep doing donuts..... I tried the soft tires ( the knobby grey bit-racer ones)...still donuts....any suggestions...or do I just try to work with it?
Old 11-21-2002, 04:17 AM
alpha1's Avatar
alpha1 alpha1 is offline
Runs with sharp stuff
You just need practice. Also, what kind of surface are you running on?
Old 11-21-2002, 04:21 AM
usagi20
Hey thanks for the reply, i'm just running on the kitchen floor
Old 11-21-2002, 08:05 AM
actofgod actofgod is offline
Bit Surgeon
First, the knobby gray bit racer tires aren't too soft. Get the real bit char-g tire set if you want softer tires. You can also gently scuff the gray ones, which will help a little. Make sure to clean the tires every so often.. dust and debris sticking to them will decrease traction.
Second, your problem is not always solved by more traction. When the car is going really fast you don't want it trying to turn at the same radius as when it's going slow or it'll spin or even flip. This is where proportional steering would come in handy. I use the really soft and squishy black tires that came with my Microsizer on the back, and knobby gray tires on the front.. but mine is going slower than yours (2.2 motor). Experiment with different combinations of tires on the front; you want them to have some traction, but enough "slip" to let the front end slide a little and make a wider turn at high speeds. The back end needs enough traction to stay firmly in place unless you're trying to do drifting. You just have to figure out if you're needing more or less traction on the front.
That's all the advice I can offer BTW I always run on a kitchen floor too, but I bet the same concepts would work on other surfaces with different tire combos.
Old 11-21-2002, 09:15 AM
usagi20
Hey thanks for the reply......would using different gearing give me better control?what about suspension? i've got the #2 strut on right now.
Old 11-21-2002, 09:30 AM
cowfish_29's Avatar
yellow fish forever!
softer stablizers mean less tration for stearing which=less donuts.
Old 11-21-2002, 09:42 AM
usagi20
i guess i was wrong, i thought the softer stabilizers gave more traction......i guess i'll play around with the suspension too...anyone use the springs from QFM?
thanks for the reply Cowfish
Old 11-21-2002, 10:43 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
springs seem like a good idea and they look neat but i dont think they really improve anything.
Old 11-21-2002, 02:52 PM
payaso payaso is offline
BIT PIMP
They totally improve the performance. They give it independant sus. Which makes the car faster. Without the springs, it's just a teeter totter effect
silla
Old 11-21-2002, 03:06 PM
r.c.dealer's Avatar
r.c.dealer r.c.dealer is offline
deviant bit char-g pro
You might want to try and dust the kitchen floor off. My Castrol Supra Booster Bit with a Handles like crap when the floor is dusty. When the floor is clean however the car handles great. Hope this helps
Old 11-21-2002, 03:08 PM
Sniper596's Avatar
Sniper596 Sniper596 is offline
I'm 1337 r/c'er :)
try running on particle board or some kind of wood that's not laminated. I get excellent grip on particle board, it is litterally impossible for my car to donut unless i use a drift axle or take off the tires. the car hardly slips on particle board so i recommend that if you plan on using a racing track or surface.
Old 11-21-2002, 04:49 PM
usagi20
wow guys thanks for all the info......i think i'll try all of them.......I had a question, how is the acceleration with the and , compaed to and ?
Old 11-22-2002, 04:10 AM
alpha1's Avatar
If you divide 12 by 30000 you get: .0004 If you divide 9.6 by 26000, you get: .0003. This number is how many times the axle will rotate for every revolution of the motor. The higher the number, the faster the acceleration. Gearing down a motor, higher gear ratio, will give you longer run times, better acceleration, but at a slower top speed.
Old 11-22-2002, 09:50 AM
usagi20
wow, hey thanks for the formula and the reply......do you have any resolutions for donuts? using springs? harder front softer rear tires? cleaning kitchen floor? running on particle board?
Old 11-22-2002, 02:42 PM
alpha1's Avatar
I just re-read my post. The formula I gave earlier was not correct. The formula should read 30000 divided by 12=2500, this number is how many times the axle will spin per minute. If you divide 26000 by 9.6, you get 2708. So if you went with the 2.6 motor, your car will actually have slower acceleration but a higher top speed. Sorry for the earlier confusion, it was late last night.
ive noticed more then just shrink tubeing on my 350z.... strtrcril87 XMODS 30 07-31-2004 10:45 PM
i wish my xmod could do mad donuts like that! skklown XMODS 14 01-16-2004 08:57 PM
Covertable 350Z project. Bad Company ZipZaps Gallery 44 01-10-2004 10:18 PM
Advice & Suggestions : 350Z The Works sS. Nomad Bit Char-G / MicroSizers 4 01-28-2003 06:22 PM
350Z issue TheEditor Bit Char-G / MicroSizers 6 11-27-2002 08:55 AM
