Go Back   TinyRC.com > 1/36 and Smaller > Losi Micro-T / Desert Truck / HIGH Roller > Micro-T General
Old 05-13-2007, 08:22 PM
JackP311 JackP311 is offline
Gear mesh noise only when cover is on?
Greetings,
I have run about 4 packs through my micro t. I took off the gear cover because I had a whine that sounded like an overly tight gear mesh. I fixed it and it sounded great. However, when I put the cover back on, I hear a whine again. Any ideas?
Old 05-13-2007, 09:33 PM
Namuna's Avatar
Namuna Namuna is offline
Hulk smash!
Sounds like you might be over-tightening the cover screws.
There's been a LOT of reports of the cover screws coming from the factory overly tight and thereby causing the gears to whine....Hopefully it's that simple for you and you just need to loosen the cover screws a little.
Good luck.
Wheel Weights! Steve ZipZaps Monster Truck 54 05-24-2006 12:40 AM
"the need for speed: a fast MT gearbox" chilli_mp138 ZipZaps Monster Truck 1 12-20-2005 05:58 PM
Gear noise... leadfootedfool SuperSlicks 3 06-28-2004 05:43 PM
Unexpected gear mesh Fix!!! cowfish_29 Bit Char-G / MicroSizers 4 10-13-2002 01:55 AM
OEM Bullet makes a lot of gear noise, can i grease it up??? SPEED Bit Char-G / MicroSizers 1 08-22-2002 06:52 PM
