Go Back   TinyRC.com > 1/43 and Smaller > SuperSlicks > SuperSlicks
Old 03-26-2004, 05:32 PM
leadfootedfool leadfootedfool is offline
Gear noise...
Is anybody else's super slick really loud??
I have a couple of bits and clones but nothing is as loud as this thing.
Any suggestions??
Old 03-26-2004, 10:11 PM
There's only one battery pack, but it is made of 2, 1.2v cells.
Old 03-26-2004, 10:21 PM
Rmc0130 Rmc0130 is offline
Send a message via AIM to Rmc0130
gears
load up the rear gear w/ some petroleum jelly- much quieter and smoother- don't go nuts w/ it though ; )
Old 06-28-2004, 05:43 PM
FMZPLAYER1 FMZPLAYER1 is offline
If you remove the two screws under the car, you easily lube the axle (it will come out). You can use a bit more lube in the middle of the axle, but be careful near the ends, too much will attract dust and lint.
Oh, also put tape on the around the idler shaft that pokes out of the chassis, it stops the hopping action that makes the gears so noisy.
Gear mesh noise only when cover is on? JackP311 Micro-T General 1 05-13-2007 09:33 PM
Wheel Weights! Steve ZipZaps Monster Truck 54 05-24-2006 12:40 AM
"the need for speed: a fast MT gearbox" chilli_mp138 ZipZaps Monster Truck 1 12-20-2005 05:58 PM
The maximum gear ratio..... charliebrown ZipZaps 9 01-13-2004 03:55 PM
OEM Bullet makes a lot of gear noise, can i grease it up??? SPEED Bit Char-G / MicroSizers 1 08-22-2002 06:52 PM
