05-29-2006, 08:21 PM
'Vette'eran
My Z can use the ZZMT controller
I know this section is dead now, but those of you that look at this section for Z car stuff, I found out something neat.
If you own a Zip Zaps Monster Truck with the same frequency as your Zcar, and your Z car has problems with battery life, range... You can put the Z car on the ZZMT controller/charger's prongues, hold it there and manually charge it for 45 seconds and then run it around with the ZZMT controller, and you might see a difference. I did with my Z car and have determined the controller that came with my Zcar is broken in the antenna.  . So if you break your Zcar controller and you own a first edition or monster truck Zip zaps controller with the same frequency then your in luck!
I Eat road kill for breakfast
05-29-2006, 11:26 PM
You can charge it on a zzmt controller, but the zzmt is a 2 cell whereas the zz is one. There is a resistance on the cell in the zz's that creates a resistance for the current to flow. Running 4 batteries is going to double the amount of current through the cell in your zz that if it were on a regular controller. It might work now, but you are going to negatively affect that cell in the long run.
05-30-2006, 08:22 PM
HAHA
2 solutions:
GET a new remote
and
BUY this battery
MOTORWORKS
[color=green]
05-30-2006, 09:31 PM
'Vette'eran
Thanks for the tip jazz32, I'll keep that in mind if I ever actually charge my ZZ on the MT controller, but we're talkin' about the Z car, which you can double charge right out of the box!(if you have been reading this section of the forum, you'de know) But I do worry though, since the zcar battery is way small than the ZZ, so the affect of the MT charger could happen more rapidly. And another thing, I can't find another controller for the zcar or remotely trust ebay or find the atomic toys web page, and you can't find zcar stuff like you could 4 years ago! As soon as I can unscrew the stripped screws on the zcar controller I'll fix or replace the antenna.
But I do appreciate the warning though  . And thanks for the tip on what battery to buy snake mod!
05-30-2006, 10:10 PM
hahaha.... he thinks I don't read the forums or know what I'm talking about.
It's true you can double charge, but again, that's a slower current rate that is much less likely to damage your battery. Charging twice on a zcar controller is not the same as charging once on a zzmt controller. There is a huge difference.
I usually double charge all my zz's, bit's, whatever micro RC vehicle I have.
05-31-2006, 03:37 PM
yeah, no one turns down Jazz32 advice and I do believe there would be a HUGE difference sorry but it's true 'vette
MOTORWORKS
[color=green]
05-31-2006, 08:56 PM
'Vette'eran
Many apologies guys, I didn't mean to be such an igmo.  I really should have double checked what I posted before I replied. I will be more considerate and more respectful the next time I post anything. Jazz is very right, So I plan to buy more AAAs and just use the original Zcar controller to charge the zcar and then use the mt controller to cover the controls so I don't fry the car. thanks alot 4 the help guys!
05-31-2006, 09:15 PM
Don't sweat it. Just double cell that car of yours, then you can charge it on the zzmt controller you want to
06-01-2006, 01:16 PM
'Vette'eran
Thanx jazz.
Great idea, I think I'll try the dual cell  . Sounds cool man!
