Old 10-05-2003, 12:46 PM
rfnagel's Avatar
rfnagel rfnagel is offline
How do you hold your SE controller?
The reason that I ask is, the owner's poster that comes with the SEs is real screwy in it's description <LOL>!
It says if you hold the controller in your right hand, to flip the switch on the top of the controller to "R", which causes the car to "move forward when you pull the trigger left, and reverse when you push the trigger right". Now, how can ya "pull the trigger left" when the controller is held in yer right hand <BG>?
I disreguarded the instructions, and for me this seems to feel the most natural (BTW, I'm right handed): I set the selector switch on the top of the controller to "L". I hold the controller in my right hand, with my right forefinger controlling the trigger (pull to the right for forward, push to the left for reverse). I then use my left forefinger and thumb to control the wheel, while the base of the left side of the controller is cradled in the rest of my fingers of my left hand.
Anyhow, I thought that the description in the owner's poster sounds rather screwy, whadyall think (or am I simply thick-headed, and don't have a clue... wouldn't be the first time <LOL>)?
Old 10-05-2003, 01:40 PM
tobenjunk tobenjunk is offline
me too
I think there's more room if you hold it in your right hand and steer with your left. Ya won't have that antenna in your way.
Although it would be nice if it was more of a pistol grip... like a pistol.
Old 10-05-2003, 03:51 PM
Bad Company's Avatar
I hold mine in my left hand. I have tried holding it with my right hand, and although it does feel better holding it that way, I have an easier time using the steering wheel with my right hand, so I have to hold the controller in the left.
Old 10-05-2003, 04:17 PM
rfnagel's Avatar
Which way do y'all have the left-right switch set to (just wondering)?
Old 10-05-2003, 05:00 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
i hold mine with my left hand with the thumb resting on top next to the antenna, ring finger and pinky kinda curled up below the controller (sorta supporting the weight of it), index on trigger with middle finger right below it resting on the controller
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 10-05-2003, 10:28 PM
Steve's Avatar
Steve Steve is offline
zipped up tight!
I hold mine like a 3 fingered crippled ape! Damn those controllers suck!
Old 10-06-2003, 07:11 AM
viperkilla's Avatar
Acura RSX
I am right handed and I hold the controller on the left side. I switched the switch so when I push it goes foward and when I pull its goes backward.
Controller trouble... Sleeping911 ZipZaps 0 06-24-2004 11:33 PM
Proportional Controller EMULATOR ph2t Bit Science 88 01-21-2004 04:12 PM
ZZ controller breakthrough! GryphicRacing ZipZaps 6 10-04-2002 02:22 PM
Sucky Booster Controller aballen Bit Char-G Mods and Projects 3 09-28-2002 05:19 PM
