Old 12-24-2005, 03:58 PM
Jetskiboy77 Jetskiboy77 is offline
Battery
Can I use this batt in my Evo Xmod? Or would my xmod explode? Its stock right now, would I need to upgrade anything to make it work. I plan on doing the FET upgrade later but I want to do the battery first and was hoping this would work without modding anythine else besides the chassis.
Old 12-28-2005, 10:03 AM
choptop choptop is offline
superzap
i think it will. it is still 7.4 volts so the evo can handle it. i had 9 volts through mine and nothing happened.you should be good
Old 12-29-2005, 12:25 AM
I was worried about the discharge rate though, would that have an affect on anything?
Old 12-29-2005, 07:38 PM
superzap
let me do some research and i will get back to you
Old 01-07-2006, 01:36 PM
superzap
the battery should work fine, it is a little big though
Old 01-07-2006, 07:11 PM
Yeah im scared its too big to fit.
Old 01-08-2006, 09:26 PM
superzap
if you have a evo f-150 you can put it in the bed, otherwise i think it may need body mods to fit
Old 02-27-2006, 10:50 PM
Xracer89 Xracer89 is offline
Send a message via AIM to Xracer89 Send a message via Yahoo to Xracer89
ya i'm pretty sure you dont have to wory abou the discharge rate.. that would just keep it cooler(the battery) and make it to where the electronics dont have to pull as hard on the battery for power.. cuz like with my Li-Ion's they get hot, mainly because i have V2.2 chip and the Fatboy HC motor.. so it pulls ALOT of power.. so ya.. i would say if you can fit it on there somewhere... go for it
Nick
Silver(and a white) Toyota Supra,
Black Skyline too
FATBOY HC motor (yellow pinon)
V2.2 chip
Locked Rear Diff
Li-Ions
AWD
Motor Wire Upgrade
Old 05-01-2006, 07:08 PM
pro-mod pro-mod is offline
Location: i live in belgium (europe), im moving to delaware (usa) soon
the only thing "discharge rate" does is give you longer runs i used two 1500mah batteries on my xmods and it ran for over two hours, only prob runing that long is overheating. if you can fit the batt, just do it. you might burn your fets after one or two hours. thats what happend to me, but i used two batt's that size. and the stage one motor. stage two would b fine
greets
Increase short battery life! underglow ZipZaps SE 1 09-17-2005 07:51 PM
Battery Runtime Tests Namuna Bit Char-G / MicroSizers 25 09-20-2003 10:35 AM
Temp 7.2 battery mod DRRfanatic425 Dynamite Rocket Racer Parts and Hop-Ups 1 08-09-2003 10:47 PM
Battery Basics 101 Namuna Bit Char-G / MicroSizers 35 06-29-2003 09:17 PM
CRAP - battery problems! syncronized Bit Char-G / MicroSizers 4 04-15-2003 08:34 PM
