Go Back   TinyRC.com > 1/43 and Smaller > SuperSlicks > SuperSlicks
Old 08-25-2004, 08:23 PM
charliebrown's Avatar
SuperSlicks CAN be FET modded....
Well, I've been studying the SS board for a while, and I know that the SuperSlick CAN be FET modded. I've traced the motor wire traces to the FETs, and I'll show you which can be replaced.
Look in this pic, the transistors circled in red are the ones which can be replaced.
Same here, the trannies which can be replaced are circled here...
Now, I just need to trace their source pins back to the power source, so I can figure out where to place the N/P channel FETs,
the N channel FETs would be IRLML2502, P channel FETs IRLML6401.
One pair of FETs is for forward, the other pair is for reverse, once again I have to figure this out...
Old 08-25-2004, 08:55 PM
UPDATE: If you look at the first pic in this thread, (top side), in the red circle, the transistor on the left needs to be replaced with an N channel, and the other tranny with a P channel, I haven't tried this yet though, I just assumed that since the tranny on the left had a black wire traced to it's source pin, then it can be swapped for an N channel FET. and the other must be a P channel...just a theory for now, I have yet to test these little babies....
Chuckster...
Old 09-14-2004, 07:53 PM
Racer9's Avatar
Racer9 Racer9 is offline
Tiny RC Pro
Cool! Do a dual stack or more when you do!
New Superslicks Fully Loaded Btman SuperSlicks 0 09-24-2004 10:51 PM
new fet design in progress 97supra97 XMODS Mods and Projects 0 02-21-2004 07:44 AM
"Quick" fet modded SE video bdebde ZipZaps SE 18 12-27-2003 07:15 PM
say GOODBYE to FET V3100! helldriver Mini-X Parts and Hop-Ups 5 10-29-2003 08:33 PM
lamborgini set and a fet modded car boho Bit Char-G / MicroSizers 4 10-03-2003 01:25 AM
