03-10-2004, 08:26 PM
AWD Question????
Why is it only three wheels spin when the throttle is applied?
03-10-2004, 08:29 PM
Because you messed up somewhere. Check all the cups.
1. Project Drag Civic
2. Offroad RSX
Often Immitated never Duplicated
03-10-2004, 08:49 PM
checked it over but i didnt see anything out of the ordinary ?
03-10-2004, 09:18 PM
Sp33D D3m0n
mine does the same thing the one front wheel doesnt spin or barely does
Getting back into the hobbie w00t!
03-10-2004, 09:57 PM
i think it might be something in the differential but im no expert. also which particular wheel doesnt spin? i had a problem like this but when i got the metal bearings i stopped having the problem.
03-10-2004, 10:13 PM
Sp33D D3m0n
front left for me!
03-10-2004, 10:17 PM
Rear Left .
03-11-2004, 05:10 PM
If you know the car is clean, or just cleaned it and still have the problem, tighten the 3 screws holding the differential together.
03-13-2004, 07:20 PM
hey mine just started doing the same thing. i thought it was the bearings so i cleaned them out real good but that wasnt it so then i thought it was the rim scraping the knuckle so i bought some washers at radioshack and i put them on and that wasnt it but that was ok because i couldnt even get the wheel to stay on unless i tightened the but reall tight until the wheel to even spin. i think that this is causing my car to turn to the left a little. its really annoting to me. i also put some gear grease in my differential. BTW it was my front left tire.
03-14-2004, 12:00 PM
I'm not a pyro, really.
try loostening the nut that holds the wheel on that might work
NEVER UNDERESTIMATE THE POWER
03-15-2004, 09:40 AM
ok i fixed it. i just cleaned out my entire car and cleaned all the bearings and stuff and now it works and it wasnt the tire becuase it still didnt spin when i took the tire off. thanks anyways.
03-15-2004, 02:36 PM
Mad Scientist
Originally posted by Vagabond
I'm glad that it work out for ya. Just remember to clean up the car after a few runs. These little cars need servicing too you know?
People often overlook the importance of good maintenance, even in the R/C world.
03-15-2004, 08:17 PM
good point. its been too many times ive seen cars smoking beside the road with a couple of college guys trying to see why their car is spitting antifreeze out of the overflow tank.
