Old 12-28-2003, 02:11 AM
MbaStylee's Avatar
MbaStylee MbaStylee is offline
range question
i was wondering, if you take off the stock little wire antenna and replace it with some copper wire that is also thicker and longer, will it increase the range and if so, will it increse it enough to actually take my time to do?
Old 12-28-2003, 06:57 AM
Bad Company's Avatar
Yes, most people end up doing this, including me. It is only a matter of one solder joint, but well worth the effort. I double my range by adding 24g wire about 3 inches longer than the stock antenna.
Old 12-28-2003, 01:19 PM
RC 2NR RC 2NR is offline
TinyRC XModder
BC, what do you mean when you say "one solder joint"?
Old 12-28-2003, 02:05 PM
The solder joint where the antenna connects to the PCB. Use your soldering iron to remove the stock antenna, and strip the end of your new wire and solder it in the same hole the stock antenna came out of.
Old 12-28-2003, 07:07 PM
inventerboy08 inventerboy08 is offline
Send a message via AIM to inventerboy08 Send a message via Yahoo to inventerboy08
be careful my friend fried he's se doing this.just make sure our decent a soldering
im not short just verticaly chalenged
Old 12-28-2003, 07:16 PM
TinyRC XModder
What do you mean PCB?
Old 12-28-2003, 07:30 PM
PCB=Printed Circuit Board: The green electronic board under the clear cover.
smart range question rydzjunior XMODS Mods and Projects 0 03-03-2007 07:39 PM
ZZMT Remote Range 88-Fiero-GT ZipZaps Mods and Projects 1 10-09-2005 09:03 PM
Question about range 05WillysJeep ZipZaps Monster Truck 2 12-11-2004 04:43 PM
range question complaisant Bit Char-G / MicroSizers 9 06-26-2003 11:16 PM
range of 27 MHz versus 49 MHz gRC ZipZaps 12 09-30-2002 06:33 PM
