Old 09-29-2002, 11:27 PM
gRC gRC is offline
range of 27 MHz versus 49 MHz
I have two ZipZaps. One is 27 MHz, and the other is 49 MHz. The range on the 27 MHz is 6 feet, and the range on the 49 MHz is 20 feet.
Is it normal for there to be such a huge difference in range?
I tried changing the batteries in the controllers, but it did not matter. I also tried removing the bodies and fully extending the antennas. The 27 MHz range increased by just 1 foot, and the 49 MHz range increased by 5 feet.
Any thoughts?
Old 09-30-2002, 12:10 AM
Namuna's Avatar
Namuna Namuna is offline
Hulk smash!
When I bought my Yellow Mustang ZZ (49MHz) I was lucky if I got 5-6 feet. So I had the opposite issue as you.
One of the very first mods I did was to put a new antenna on it. I used a solid core, 24guage wire (bought from Radio Shack). Now my range is in the 15-20ft range.
If you're handy with a soldering iron...I HIGHLY recommend replacing the antenna on the car.
Old 09-30-2002, 12:14 AM
JediYoda56 JediYoda56 is offline
Send a message via Yahoo to JediYoda56
Namuna: I see alot of mods seems to involve a soldering iron. How woul done go about buying and learning how to use a soldering iron? Thanks
Old 09-30-2002, 12:40 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
heh im not sure how far mine went, i ran out of batteries
i expected it to use AA batteries..then when i open it up im like dammit...so i had to use some old ones hahah
well i think it went about 15 feet....
i tried to see if i could lengthen it by unwinding the wire, but there was none left inside ;/
ahh wells
ALSO!!! i saw some guy return his ZZ because he said it wouldnt go far..i laughed....
Old 09-30-2002, 12:46 AM
headhunter555 headhunter555 is offline
The Lexan Body Pro!
Yeah my 27 doesnt have much range either! maybe 7 feet MAX!
~~~Bash it Bash it Good!!!~~~
Old 09-30-2002, 01:40 AM
gRC gRC is offline
I fixed it!!!
I opened up the circuit board compartment and moved one of the fine copper wires. These wires are bare and as thin as hair. One wire seemed to travel too close to the circuit board, perhaps touching part of it that it should not. So I carefully moved it away from the circuit board by pushing it with a tiny screwdriver.
Now both the 27 MHz and 49 MHz have a range up to 25 feet.
YMMV.
Old 09-30-2002, 03:34 AM
payaso payaso is offline
BIT PIMP
I know this is for Namuna, but he's not here and I am, so go to your local radio shack and buy a soldering iron and a do it yourself radio or something and practice with that. When you feel confident enough to do it to your bit, go for it
silla
Old 09-30-2002, 11:21 AM
Namuna's Avatar
Hulk smash!
To add-on to what Payaso said...
Look for a 20 to 30watt soldering iron, with the 'sharpest' tip you can find (like sharpened #2 pencil sharp!)...As a matter of fact, they're usually called Soldering Pencils.
Here's a decent one from Radio Shack: HERE
Along with that you'll...Bah, I'm adding this to the FAQ
Old 09-30-2002, 03:10 PM
BIT PIMP
I have that same iron, but mine is only 15 watts...
It still works ok though...
silla
Old 09-30-2002, 05:11 PM
Namuna's Avatar
Hulk smash!
So do a 30watt MOD on it!
Old 09-30-2002, 06:43 PM
BIT PIMP
How???
silla
Old 09-30-2002, 06:54 PM
Namuna's Avatar
Hulk smash!
You go out and buy a 30watt version, that's how.
...I'm KIDDING about the mod!
Old 09-30-2002, 07:33 PM
BIT PIMP
Yep, we're definitely related....lol
Doh... I walked right into that one. Looks like we have another payaso in here..
silla
27 mhz vrs. 49 mhz or is it Regular vrs SE Sleeping911 ZipZaps SE 4 08-13-2004 10:14 PM
Spring ant. and TV ant. range tests Azimov ZipZaps 3 05-05-2003 09:37 PM
02 MHz and other odd MHz noxorc Bit Char-G / MicroSizers 3 02-23-2003 06:49 AM
poor range? GTR ZipZaps 3 11-18-2002 03:54 PM
HELP! Horrible range with 27 Mhz Telstar ZipZaps 3 11-12-2002 09:28 PM
