11-22-2003, 06:57 PM
0reZepyT
7.2 Volt 6 Cell Mod Steering Chatter
to anyone who has done the 6 cell mod, does your XMod's steering chatter like it's trying to center? if i turn teh steering or lightly nudge the front wheel, the chattering stops.
oh yeah, i just checked the light connector with my DMM, the reason things get fried is because there's over 7 volts coming out of that connector
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
11-22-2003, 08:53 PM
got boost?
ok
thank for important inforamtion
All Wheel Drive=Fun!!!
11-22-2003, 09:36 PM
yes my servo chatters its not usually a issue as in about 1 min after the car is on its driving around. and yes over 7 volts comes out of the conector were the lighs plug in.but the little chip on the lights knocks that voltage down to a usable voltage. I mean its entirely possable thing could die but their should be no reason the raido should be damaged i do not see why the only reason i can see is if power was feeding back into the system some how. Ill investgate more my self.
Stand Tall and Embrace the fires of Legend.
11-22-2003, 09:58 PM
0reZepyT
hmm, maybe the people who had fried their cars with the 6 cells and the lights had parts on their ESC that were on the low end of what RS deemed acceptable in their so-called "Quality Control" and thus the 6 cells brought it right to the edge and the light kit jus kicked it over and killed it. so far i heard of 3 people who returned/exchanged their xmod cuz they fried it and 2 or 3 people who's running lights with the 6 cells so it's like a 50/50 thing. i might try it later but if i fry it, yeesh, gotta wait til they come out with the ESC repalcement or else shell out 50 bucks for another chassis =T
11-23-2003, 03:19 AM
0reZepyT
i don't think the command light is doing anything to regulate voltage. all it is on that little board are two transistors, two caps, two resistors, some traces and the wires. i would think the transistors would burn out if it wasn't designed for 7 volts (IE radioshack used cheapest parts possible)
11-23-2003, 03:20 AM
0reZepyT
reverse side
11-23-2003, 03:23 AM
Just seems kinda nutzo I have never seen a 7 volt led only seen 3.6 5v and 12 volt and usually a 5 volt item would crash and die at 7 volts .. lol this is were it would be nice to see a Skim on how the entire car was built all the bits and pices.
11-23-2003, 03:29 AM
0reZepyT
led's are a mixed bag to me, i bought the brightest blue led radioshack had (3500 mcd or so) and was rated for 5 volts. well, i hooked it up in my computer to let me know if a fan is turned on or not and well, it's getting 12 volts for the past couple of years and it hasn't burned out. on the other hand, i tested out a couple diff yellow led's from radioshack, which btw, was NOT yellow, it was amber!!, anyway, i bumped it tiny bit over 2 volts (rated for 2 volts max) and it blew out. returned both
11-23-2003, 12:56 PM
0reZepyT
yeah, it'll be safe. if you just got your xmod and you don't mind exchanging it, you could try the light kit for yourself if you desired.
11-24-2003, 06:20 PM
0reZepyT
well, bit the bullet and i'm glad to say, NOTHING got fried when i plugged in my light kit. couldn't test brake lights cuz the wire on the chassis' connector has been loose for a long time and soldering/desoldering it over and over couldn't fix it (though pressing down on the plug worked at one point but not anymore).
