09-24-2003, 09:46 PM
to manny donuts
09-24-2003, 11:43 PM
You should get softer tires. Cleaning the tires and floor would help.
09-25-2003, 05:16 AM
use the stock tires that came with the car, those are as soft as you can get. Only use hard tires for the fronts, thats problably your problem, if you use them for the rear its non-stop donnuts unless you're running on hotwheels track.
09-25-2003, 11:02 PM
Camera springs
Yeah, microspeed gots the flow. The cars are a little front heavy when they come stock. You'll need to either reduce weight in the front, change the center of gravity, put more weight in the back or a simpler solution is to just give it less traction in the front and more in the back. Example: Slicks in front and softs in back.
