03-30-2003, 10:19 AM
tire combo
what is the best tire combo......ive been trying many combos because wen i floor it my car will always just spin out........i cant figure out why....i need help!!!!!!
03-30-2003, 11:05 AM
NSX Driver!
Personally I use pullback wheels in the back and johnny lightning wheels in the front.
03-30-2003, 11:08 AM
{{ x | NO CARRIER
Bit Char-G red tires work very well in controlling spinouts.
03-30-2003, 11:11 AM
i have the microsizer set of tires with the soft medium and hard tires
03-30-2003, 11:56 AM
{{ x | NO CARRIER
The problem is those are actually Bit Racer tires. The compounds used to make those tires are significantly harder than what Bit Char-G tires need to be.
(I bought that MicroSizers tire set before I knew this, so don't sweat it.)
What would work exceptionally well is the Bit Char-G Setting Parts Set GS-07. It has red, purple and light blue tires. They are excellent, and the red tires really are quite sticky. Even the hardest of these is softer than the softest Bit Racer tire, I believe.
Here's a link to the set I am speaking of.
03-30-2003, 12:06 PM
Red tires in back
I put the red ones in back so that I don't spin, but I put the blue ones in front so that I don't flip at high speeds. Adjust your tires to the surface your on -- try different combos. I race on smooth masonite, and I need the red tires in back. Hard wood floors are even worse if they have been finished/refinished recently; without soft tires in back it's like driving the drifting axle.
03-30-2003, 12:07 PM
t hanks that helped alot
03-30-2003, 03:31 PM
NSX Driver!
By some nos in a spray bottle for 1/10 scale nitro remote controll cars and spray it on the tires you will have tons of traction.
03-30-2003, 04:37 PM
i think im gonna try that...............wen i try new combos it works AWESOME for like 5 mins then all of a sudden it'll start spinning out
03-30-2003, 04:46 PM
Gotta clean the tires
Tires accumulate dust -- just roll the cars on masking tape after a few races to get the dust off.
03-30-2003, 04:58 PM
after it starts spinning out i usually just wipe it off but then after 5 mins it still spins out.........and its a pain to keep on cleaning it off
03-30-2003, 05:30 PM
Blitzer Sonic
What you want is the softest tire set without spin outs. Try out the softest tire combo by putting on your softest tire on all 4. You will probably flip over od do a super fast and sharp turn. If it is doing that, put harder tires on front. Keep un getting harder in front until it works well. If you cant turn sharp enough, make the back tires harder so it kind of slides like drifting. On my dual cell fs mod, stock tires in back and soft treaded in front work best.
03-30-2003, 05:35 PM
thats the combo i have on it right now it still spins out
03-31-2003, 02:40 PM
anyone?????
03-31-2003, 03:20 PM
Which combo do you have right now?
Are you saying you have the red tire on right now? Be specific -- both front and back. Also what surface are you racing on?
