Old 09-01-2002, 03:37 AM
sneuburg sneuburg is offline
NiMH mod - Excellent!
I just did this mod about an hour ago and am impressed. It was my first REAL mod but was very easy. The first time I charged it for one 45 sec. cycle and ran it for about 15 min. I then charged it for another 45 second cycle (the battery was NOT dead at this time, mind you) and ran for 30 min. before I just gave up on trying to see how long it would last. Granted, the last 10 min. or so showed degraded performance, but that first 15-20 min. it ran faster than ever! Maybe it's just my imagination, but I could've sworn it was faster!
Question - I read somewhere that you should charge it for 2 consecutive cycles, so I tried this and the charge light would not come on the second time I tried to charge it. Is it charging anyway? or am I doing something wrong?
Old 09-01-2002, 02:56 PM
tinyrc's Avatar
tinyrc tinyrc is offline
When you charged it the second time, did you completely remove and then replace the car?
Old 09-06-2002, 11:14 PM
Redfire's Avatar
Redfire Redfire is offline
Just kinda burned you...
Send a message via AIM to Redfire Send a message via Yahoo to Redfire
Same thing happened to me. At first, i thought my battery died on me, so i replaced it. But the problem wasnt the battery, all you have to do is wait a few seconds after your first charge (10-15), and then charge again! It should work!
"I won't lose, no matter what, because the prize is a full tank of gas." Takumi
Old 09-07-2002, 05:11 AM
Thanks Redfire,
I had to wait about 45 sec. to a minute, but it worked. Only this time my run time was considerably shorter (7-8 min). That's a great run time but nothing compared to the 30+ min I got after first doing the mod.
hmmmmmm.....
Silver Honda S2000 (57 MHz)
2.2 Motor
Orange Gears
Gold Spring Suspension
NiMH Battery
Old 09-07-2002, 09:03 AM
Redfire's Avatar
Try doing 3-4 continual charges, it should give you that 30+ minute runtime you want.....
Old 09-08-2002, 01:33 PM
1coolskyline 1coolskyline is offline
Send a message via AIM to 1coolskyline
how do you do this mod? Whats the cost and tools needed? Oh yeah whats the negative side effects on the car?
where ever you go there you are!
Old 09-08-2002, 05:03 PM
tinyrc's Avatar
http://tinyrc.com/qfm/racing/mod_04.htm#14
dual batt mod with two 100 mAh nimh battery I2ed ZipZaps 2 12-19-2002 09:49 AM
batt mod with two 100 mAh nimh battery I2ed Bit Char-G Mods and Projects 0 12-17-2002 10:18 PM
Can I mix NiMH and NiCd for dual battery mod? Def Bit Char-G Mods and Projects 5 09-30-2002 02:14 PM
NiMH Cell mod Bez Bit Char-G / MicroSizers 9 09-01-2002 03:51 AM
