11-25-2002, 02:20 PM
Axle Slot Problem
My micro sizer has kinda dissapointed me that you cant take off the axle too many times or it will be impossable to run because slot is so open and axle fall out any 1 else have this problem or know a fix 4 it
KAMAKAZEE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
11-25-2002, 02:30 PM
Toy Collector
I change my axles regularly and never had that problem. Did you put some sort of lubrication on it?
NSX-R , FairladyZ33, Auto Modellista, AE86 Trueno,
Calsonic R34, R34(WHT), Evo VII(YLW)
11-25-2002, 03:22 PM
ZipZap Maniac
look in the zipzap section there are numorous post about this issue.
1999 Super Modified Zinc Yellow SVT Mustang ZZ
Bit PCB MOD
It's a sleeper! hehehehe
M/S Mitsubishi EVO Lancer w/modified clone motor
M/S Nissan Skyline
M/S Honda S2000
11-25-2002, 03:58 PM
Hello can you tell how I could get my picture on my name.
Thank You!
11-25-2002, 04:11 PM
Toy Collector
hello
in the top of the page on the main forum screen, there s a button called "USER CP"... click that and click on edit options. At the bottom of the screen you'll see "Avatar". You change or add your picture there.
11-25-2002, 04:16 PM
Thank You!
11-26-2002, 01:56 AM
i used a little bit of elmer's glue. using a toothpick, i made sure it didn't clog the slot. i read that some people used epoxy or crazy glue, but i think elmer's glue is easier to work with. it dries slower, but that just means more control. just my thought.
11-26-2002, 10:15 AM
axle problem
I would install me gear set then I would make small wedges for the slot you could cut them out of small plastic to slip in place.
Good luck it sounds like you stripped your slot.
