-   -   Axle Slot Problem (http://tinyrc.com/forums/showthread.php?t=3851)
Colt45101st 11-25-2002 02:20 PM
Axle Slot Problem
My micro sizer has kinda dissapointed me that you cant take off the axle too many times or it will be impossable to run because slot is so open and axle fall out any 1 else have this problem or know a fix 4 it
Blue Bit 11-25-2002 02:30 PM
I change my axles regularly and never had that problem. Did you put some sort of lubrication on it?
marc515192 11-25-2002 03:22 PM
look in the zipzap section there are numorous post about this issue.
J. Gandia 11-25-2002 03:58 PM
Hello can you tell how I could get my picture on my name.
Thank You!
Blue Bit 11-25-2002 04:11 PM
hello :)
in the top of the page on the main forum screen, there s a button called "USER CP"... click that and click on edit options. At the bottom of the screen you'll see "Avatar". You change or add your picture there.
J. Gandia 11-25-2002 04:16 PM
Thank You!
eyebee127 11-26-2002 01:56 AM
i used a little bit of elmer's glue. using a toothpick, i made sure it didn't clog the slot. i read that some people used epoxy or crazy glue, but i think elmer's glue is easier to work with. it dries slower, but that just means more control. just my thought.
J. Gandia 11-26-2002 10:15 AM
axle problem
I would install me gear set then I would make small wedges for the slot you could cut them out of small plastic to slip in place.
Good luck it sounds like you stripped your slot. :blift:
