Old 07-01-2006, 12:24 PM
flamehead_16's Avatar
flamehead_16 flamehead_16 is offline
Naruto Champion
Slammed Wheels
can you put the slammed wheels from the truck on the mustang?
People come and go, but no one stops and looks.
Black/Red F150- Lift kit, body lift.
Black Camaro- 6th cell dragster with custom tires.
Blue Mustang-Slammed wheels
Black Hummer- Everything
Old 07-01-2006, 01:56 PM
Jazz32
all the wheels go on the same way, so I don't see why not. Trick will be getting the body to fit right. Try it out and see.
Old 07-05-2006, 10:05 AM
Naruto Champion
i did and it worked
Old 07-13-2006, 12:33 PM
NEO-R NEO-R is offline
I tried that with a G35 and it still didn't fit. Even after cutting some plastic out of the fenders, but it turned out that I needed to widebody the sucker, and I have NO experience with putty work...But hey, if you found another way to pull it off, let me know. Thanks.
Where did the time go?
Old 07-13-2006, 03:32 PM
Naruto Champion
i used it on the mustang. i used the UP suspension and had springs.
Old 07-13-2006, 04:17 PM
This I gotta see... Can you post pics or something?
Old 07-13-2006, 04:44 PM
Naruto Champion
here...
Old 07-13-2006, 04:50 PM
Ah, so it barely fits. At least it works, right? Since I couldn't fit mine onto my G35 in the end (due to a crappy buget), I gave my wheels to someone else, but maybe I should see if I could get them back if he's not using them... Put them on Project: Supah Seven, perhaps...
Old 07-13-2006, 05:17 PM
silentracer's Avatar
silentracer silentracer is offline
you should sand out the wheel wells and lower it back down. then u'll have ultamite handling, and it will look sick.
Old 07-13-2006, 05:49 PM
Naruto Champion
it is so close to the sides but all the wheels turn
Old 07-13-2006, 10:33 PM
Jazz32
Plus you're gaining ground clearance and higher top speed!
I'd do this if those wheels didn't cost so darn much.
Jeep with Lego Wheels For Sale viperdout ZipZaps 2 06-03-2004 04:34 PM
lego wheels on like stock wheels sawhit4 XMODS Parts and Hop-Ups 4 02-18-2004 07:29 PM
stuff caught in wheels jbach39 ZipZaps SE 10 10-26-2003 06:38 PM
fs. 27mhz booster chassis, Pullback wheels on knckles +axle, +bodies!!!! eman1 For Sale/Trade 7 09-11-2003 08:39 PM
Full size wheel/small wheels mods... Awaken For Sale/Trade 2 05-20-2003 01:49 PM
