The joystick controller mod shouldnt affect the transmission of your signal at all simply because the joysticks dont actually make contact with "anything". They only attach to the plastic controller buttons. Be sure that the backside of the joysticks arent making any contact with the circuit board, maybe the screws are touching the board. Or possibly when dissassembling the controller, you may have bent or introduced a foreign metal particle into the controller?
AS far as the upgrade antenna on the car, you should have improved signal because you are now using a solid copper core wire. CHeck to make sure the solder didnt overflow and make contact with anything else on the Bits circuit board. Let me know if this helps.
