Old 05-31-2005, 08:32 AM
Lucky7 Lucky7 is offline
Internal Antenna
Not sure if this is the right place to ask but here goes. I read somewhere else that you could make an internal antenna for your Xmod by taking a peice of wire 3 or 4 times the length of your original antenna, making a coil, and placing that coil under the body. The wire has to be coated of course to prevent shorting. But is this feasible? Will it work without affecting range? If it does that would be so sweet. No antenna sticking out of the body to catch on stuff. Plus easier to store the car.
Blk Civic - Suspension upgrd (blue rear/yellow front), Blue Wheel Nuts, CF bumper.
Silver RSX - AWD, Suspension upgrd (Yellow F/R), Purple Wheel Nuts.
Yellow Skyline - AWD, Susp upgrd (Yellow F/R), Stage2 White motor, Blk wheel nuts.
Red Supra - RWD, Stage2 Red motor, Red wheel nuts.
All use TinyRC Bearings
Old 05-31-2005, 11:52 AM
skyline_69's Avatar
skyline_69 skyline_69 is offline
SkyineRC Pro
Send a message via AIM to skyline_69
i have tried a couple different methods of making an internal antenna, but havent had any luck getting good range...usually only about 10 feet...but i know that you have to get the wire length just right...well, good luck...im interested to see if you find a solution
-1999 Nissan Skyline GT-R 34
-Paint in the works
-Airbrushed Wheels(stock)
-Mesh Front Grill
-Stage 2 SB Hybrid Drift Motor (8 tooth)
-AWD
-CL Lights
-CL Underglow
-6 CELL BABY!
Old 05-31-2005, 12:02 PM
Originally posted by skyline_69
[b]havent had any luck getting good range...usually only about 10 feet...but i know that you have to get the wire length just right
That is what I figured. I'm gonna give it a go and see what happens. Just being able to store the cars easier is worth a try. Now you either unscrew the antenna or bend it over close to the body. Neither of which I want to do all the time. Going to try making the coiled internal antenna 21", three times as long as the original. See what happens.
Old 05-31-2005, 08:50 PM
Well tonight I sat down and tried a few different internal antenna's. None worked all that well. I measured the one on the car and made mine 3 times longer.
Long coil - Jerky and stuttery
Stretched around the interior of the body - Better but still short range.
Wrapped around a piece of 2" x 2" cardboard - Same as above.
In the end I cut it the same length as the original antenna and put it up through the hole. Works great and allows me to bend it for storage.
I did examine and measure the antenna's on my cars and from what I can tell each is exactly the same length no matter the crystal they are using. Apparently they are not 'tuned' to each car. Besides, if you can use any of the crystals in each car without changing the antenna does that not say the antenna makes no difference? At least as far as the original. Longer antenna's may have to be certain calculated lengths. But if each antenna is exactly the same length then each longer antenna would end up the same as well.
Old 06-01-2005, 09:25 AM
Capt.ArD Capt.ArD is offline
I am sure i've seen people do this before, and i'm sure it works. you do have to get tghe length just right. there is some kind of formula though. do a search and i bet you can find it. if i recall, though, the guy who did it wound a cardboard strip with about 5 or 10 feet of cat 5 wire. may be too heavy if you want to race with it...
skyline, black
Spinbrush motor with capacitor mod, 10-tooth pinion, blue spings, 3.0 tie rod, lego tires, AWD. Plastic driveshaft.
rally!
Old 08-09-2005, 03:43 PM
Nutz4subarus Nutz4subarus is offline
Location: Hick town P.A (we got a kicking x-Mod Track though)
Send a message via AIM to Nutz4subarus
Lightbulb CANED HEAT
OK, I got the answer to your question TYCO Caned Heat......
The internal ant that it in them works rather well, but if you chose to make your own you must make shure that the wire is able to cunduct the same 24-29 MHZ that the stock puts out. 3-4 time stock length is good... Mike
The thinker
Old 08-09-2005, 07:43 PM
Horshu Horshu is offline
Obsessive Modder
With antennas, the length has to be a power of 2 relative to the wavelength. I can't remember the lengths (there are plenty of calculators for wavelenghths), but basically, it has to be 1x, 1/2, 1/4, 2x, etc. of the wavelength intended to be received. Because the crystals only alter the base wavelength slightly, the same antenna works for all supported frequencies.
Old 10-29-2005, 02:21 AM
gyrate gyrate is offline
it will never work with the xmods' (evo included) crappy tx and rx.
you can pull it off on real rc stuff though and yes, you will cut range still but at least you can reach 50 feet, not 5.
Old 03-21-2006, 08:58 PM
somebody5788 somebody5788 is offline
I used Cat 5 wire on my evo truck and stuck it staight up without measuring it works from my house down to the end of my ally without getting choppy... its at least 100 feet!!!
Old 03-23-2006, 10:19 PM
NEO-R NEO-R is offline
I heard that a copper screen or mesh makez an excelent internal antena
Where did the time go?
Old 01-06-2007, 11:14 PM
anticasper86 anticasper86 is offline
Send a message via AIM to anticasper86
i dont really understand in this you guys are jumping steps. from step one how do u make a good internal antenna (sorry for the attitude long xmod day)
SCION
4WD
yellow suspension front axle
blue suspension rear axle
drift tires
decals kit
stage 2 motor 9-25
reachargable rs batteries
NSX
rs rechargables
stage two white
body kit
foam tire
CIVIC
rs rechargables
AWD
body kit
metal bearing
stage two red
yellow front/ back suspension
tie rods
Old 01-08-2007, 10:21 AM
nismology's Avatar
nismology nismology is offline
ive got a tyco canned heat and the range sucks! its about 5ft!
Old 02-25-2007, 08:16 PM
ledhedgn ledhedgn is offline
sorry for the bump, but this thread wasn't far down from the sticky's in the first place.
wouldnt the problem be either the receiver in the car, or the emmiter in the controller, if so, find out what resisters are being used in the range repair kit, and get resistors that are less by a bit (they look like resistors, not 100% sure if they are or not)
internal antenna? kasper01001 XMODS 2 02-23-2004 08:22 PM
need a new TX antenna? TypeZer0 XMODS Parts and Hop-Ups 3 02-15-2004 07:09 AM
Alternate antenna ideas! caver01 Bit Science 214 11-07-2003 09:38 PM
FS: Internal Dual Cell Bit w/ telescopic antenna upgrade syncronized For Sale/Trade 1 06-09-2003 09:39 PM
cat5 antenna for internal wiring 8ate8 Bit Char-G / MicroSizers 5 12-26-2002 04:59 PM
