Old 12-08-2003, 06:35 PM
geofroley's Avatar
R34 Skyline is God
I'll be using an independent battery, not the cars power. Also I need to know how to set up an on/off switch for it.
My Bit: Phast motor (Orange)
Soon to come: (Undecided) Custom Rims
Old 12-08-2003, 11:07 PM
LP_Reanimator LP_Reanimator is offline
i don't think it would look good. And i really don't see how it would be feasible, since most of those lights are really big. And besides, most underbody light kits are different colors other than regular, and the only kits that have all one type of light are the regular lights. For example, if you wanted purple lights, there is no way to get all purple lights unless you get a multi-colored light kit and take out all the purples and somehow splice them all together in one string and somehow fit them under the body. And you'd have to do that at least twice to get it on either side, or more if you wanted it in the front and/or back.
Old 12-08-2003, 11:35 PM
tavisjohn's Avatar
tavisjohn tavisjohn is offline
RC Tinkerer
The bulbs are removable. You could get a short string of 6 bulbs then remove all the bulbs so you are left with sockets. Then you just plug in the bulb color you want.
Old 12-09-2003, 03:41 PM
Well yeah, that's true. And if you get it to look like there's not light bulbs under there, but rather one continuous row of light, then that would look good.
Old 12-11-2003, 11:48 PM
Plays_with_Toys Plays_with_Toys is offline
Re: ok I got to tell you guys
Originally posted by shaneomac326
ok I have go to tell you guys this www.hobbylogic.com simple as that
coughanyone can point a single led at the ground and call it a neoncough
If you guys are too lazy to try the straw+LEDs, Wavejake RC is looking into releasing some.
AWD Xmod Crawler in the works _>
Landcruiser Z-body, AWD w/ Locked Differentials, Spinbrush motor, 30x14 Lego MT/R's
Old 12-12-2003, 04:39 PM
funkytones funkytones is offline
okey... then i'll change it...
coughanyone can point a 7 single leds at the ground and call it a neoncough
happy now?
Old 12-12-2003, 05:11 PM
Haha....
Sorry, but the point of it is that it dosen't look like a neon. It looks like a light directed straight at the ground, and even has a fade like its only one light.
True ground effects or neons go the length of the car, or illuminate the entire underside of the car, basically replacing its shadow with glow. In order to do this, you need the light to come from all over, not be concentrated into one spot.
And yes I did look at the site, but didn't see any pics of the kit itself, only the demo pics with it mounted to the models, and I just wasn't impressed. They did a good job with the wheel well lights and the under hood lights, but I didn't look deep into how they did it, and maybe they look good on the models, but would have no crossover into anything RC, since models generally have no moving parts to contend with.
Old 12-26-2003, 03:57 PM
teamdeadbunny's Avatar
teamdeadbunny teamdeadbunny is offline
Track Master
Why not just use the light kit itself, reroute the leds to shine under the car in each wheel well, maybe slip those little rubber led covers that are coloured over it for the colour you want... or use stage lighting gels to create the light effect?
Just an idea.
I was thinking about using the parts I originally got for my Bit Char-G light kit as my underglow kit. I was just going to put light coat of coloured paint over the led and then run them down into the wheel wells. THen tap it directly into the battery.
Havent tried it yet however.
Old 12-27-2003, 11:14 PM
hotrod29728's Avatar
hotrod29728 hotrod29728 is offline
Send a message via AIM to hotrod29728 Send a message via Yahoo to hotrod29728
did anyone ever think of even splicing the wires on the light kit and just running some wire and LEDs off of that?
you could like put two on each side facing one another on each side of the battery pack like this LED [ ] LED and put like two on one wire and two on another
since it was my idea if someone makes on ill sed them money and buy one if theyll build it lol im to lazy to build anything i just make ideas
Current XMods:
Black Skyline: Stage II Motor
Current Microsizers:
Current Zip Zaps:
Black 68 Camaro SS
Red 25th Anniversary Camaro
Black Chevelle SS SE
Mazda RX-7 SE
Mazda RX-7 SE
Silver Pontiac Trans Am
Orange Mustang SE
Old 12-28-2003, 08:46 AM
Bad Company's Avatar
I did that a while back (have to search for the post), and it takes way more than 2 LED's to make it look like light coming from under the entire car.
Old 12-28-2003, 01:57 PM
baleisen baleisen is offline
Micro R/C'er in Da Burgh
Send a message via AIM to baleisen
I'm looking into the LEDs and clear straw idea right now.
BAE
Smaller models, more control
Old 12-28-2003, 11:10 PM
What are you using? BAE
Old 12-29-2003, 12:55 PM
dero dero is offline
could you just have 1 LED and use electral tape to tape fiber optic strands to it? Then arrange the ends of the strands around the car? I think this would make a more even under glow, and one led wired to the exsisting batery wouldnt eat up too much power. just my 2cents
Old 12-29-2003, 06:26 PM
I Shall Return!
ok i have yet 2 ideas for underglow... the first is hard, take some clear straws and cut the to length, then cut a lil peice of aluminum foil and sneak it in the straw, have it only covering half of the inner straw, then do B.C's led splice and place a led at both ends of the color of your choice... i dont know the results because i havent tried.. the second came to me last night, i was messing with my phone and saw a little stick of light (the screens backlight) its small, bright and runs on low voltage, im not saying tear apart all of our cell phones for these but ill investigate where to buy these back lights... ill report soon!
Old 12-29-2003, 06:34 PM
I Shall Return!
reporting
http://www.laptopsolutions.plc.uk/lcd_backlights.htm
also we could tear apart digital watches (cheap ones)
easiest and best underglow ever bengali548 XMODS Parts and Hop-Ups 2 08-05-2006 01:08 AM
New idea for neon underglow J-Tuner XMODS 4 12-18-2004 11:12 PM
idea for battle feild! Comrade_Boris Combat Digi Q 10 11-02-2003 04:46 PM
What do you think about this track idea? sneuburg Bit Char-G / MicroSizers 1 09-08-2002 06:30 AM
