Old 11-05-2003, 03:55 PM
psing23
question about my supra w/ most mods...
i have a supra w/ stage 2 motor upgrade w/ 8 teeth, foam tires, AWD, suspension, rechargable batteries, body kit
what are the best settings for suspension with my AWD and stage 2 motors so that i have the best handling and will improve my turning radius...
im riding on comercial grade hard carpet w/ the foam tires.
my turning radius sucksssss... i tried so many different configurations, different stiffness springs, all the toe-in bars, using the red differential, the white differential, interchanging the red and the yellow suspension parts...
im stuck i dont know what to do the car is apart more than its together... i can't enjoy it...
i tried searching but i cant find anything....
Old 11-05-2003, 04:11 PM
SuperFly's Avatar
SuperFly SuperFly is offline
bitPimp
This might be obvious, but did you turn the steering trim dial to "maximum" on your controller?
Otherwise, I would look in that little magazine that came with the car and do everything that promotes oversteer. Soft springs and tires up front; hard, stiff in rear
A more extreme measure can be found here
Also, as I understand it, the stock tie rod/steering arm will give the smallest turn radius. Shifting your batteries to the rear-most setting will help as well.
Old 11-05-2003, 04:18 PM
psing23
yea... everything is adjusted on the controller properly, the steering range, the throttle...
i might try out adjusting the toe-in rods..
i dunno whatelse i have to do...
Old 11-06-2003, 01:21 PM
WytSoupBra WytSoupBra is offline
I'm gonna try that hot salt trick... I didn't even think about it...(duh) hahah how clever... what can it hurt... I don't notice a difference at all between any of the tierods in the suspension upgrade... the springs change a lot of the handling.. but the turning radius is $hitty on any degree.
Battery mods and voltage tolerance... ib_ant Plantraco Desktop Rover 0 02-24-2004 03:17 PM
What mods to do? BrokenMonkey XMODS Mods and Projects 7 01-27-2004 12:21 AM
i need som mods for a supra and i'm new at this suprafan420 ZipZaps 6 10-06-2003 09:29 AM
Question for Bitchar-G Supra owners! heuerfan Bit Char-G / MicroSizers 1 10-10-2002 03:30 PM
Bit Char-G Supra question. . . andrzejpw Bit Char-G / MicroSizers 21 07-30-2002 08:34 AM
