question about my supra w/ most mods...
i have a supra w/ stage 2 motor upgrade w/ 8 teeth, foam tires, AWD, suspension, rechargable batteries, body kit
what are the best settings for suspension with my AWD and stage 2 motors so that i have the best handling and will improve my turning radius... im riding on comercial grade hard carpet w/ the foam tires. my turning radius sucksssss... i tried so many different configurations, different stiffness springs, all the toe-in bars, using the red differential, the white differential, interchanging the red and the yellow suspension parts... im stuck i dont know what to do the car is apart more than its together... i can't enjoy it... i tried searching but i cant find anything.... |
This might be obvious, but did you turn the steering trim dial to "maximum" on your controller?
Otherwise, I would look in that little magazine that came with the car and do everything that promotes oversteer. Soft springs and tires up front; hard, stiff in rear :eek: A more extreme measure can be found here Also, as I understand it, the stock tie rod/steering arm will give the smallest turn radius. Shifting your batteries to the rear-most setting will help as well. |
yea... everything is adjusted on the controller properly, the steering range, the throttle...
i might try out adjusting the toe-in rods.. i dunno whatelse i have to do... |
I'm gonna try that hot salt trick... I didn't even think about it...(duh) hahah how clever... what can it hurt... I don't notice a difference at all between any of the tierods in the suspension upgrade... the springs change a lot of the handling.. but the turning radius is $hitty on any degree.
| All times are GMT -5. The time now is 09:51 PM. |
