Old 10-31-2003, 11:55 PM
v0lc0m85 v0lc0m85 is offline
Send a message via AIM to v0lc0m85
radio cutting out
i had my skyline for a few days and it worked fine. yesterday i put in all wheel drive and the drift stage 2 moter. once i got it all back together i went to run it. it works fine but once it gets like 10-15 feet away from me it looses signal. the antenna is hooked up and the controller antenna is on. i duno what happened. i think the antenna wire touched one of the batteries while i was installing the awd, but only for like a second. im not sure whats wrong with it or how to fix it.
Old 11-01-2003, 01:51 AM
I have a beach ball...
Battery in the Tx
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 11-01-2003, 10:29 AM
metsrule119's Avatar
metsrule119 metsrule119 is offline
Actually, they suck^
Send a message via AIM to metsrule119
yea its definately the battery in the controller-
This happened to me so I took a piece of masking tape and rolled it up to the thikness I needed it and put it between the battery and the battery cover/door.
1 Xmod w/ the works
2 Microsizers
1 Zipzap
1 Zipzap SE
1 Toy East Mini Cooper
1 Precious Clone
Old 11-01-2003, 10:33 PM
hrm, i tried what you suggested and jammed some paper into the controller to make the battery have a tighter fit but it still cuts out after it gets like 10 feet away from me. any other suggestions?
Old 11-02-2003, 12:31 AM
Try a new battery.
'65 Ford Mustang
All the RS goodies
Old 11-03-2003, 11:27 AM
gnubee gnubee is offline
mine is doing the same thing..batt in tx is ok..good contact..10 foot range then a stuttering..this is the 2nd one and still tx problem..ant in tx seated well.happened when i put in stage2 and bearings and awd..the front to back drivetrain shaft is really wet w/lube i pulled it out+put it back in during bearing install.could it have fouled something inside?/
Old 11-03-2003, 11:41 AM
well i just got fed up with it and returned my car. they took it even tho it was all scratched up and i broke one of the mirrors. i just finished putting in the stage 2, awd, and a light kit again and it works fine now. thank god
Old 11-03-2003, 12:15 PM
_revhards13 _revhards13 is offline
I think thier cute!
Send a message via AIM to _revhards13
if it smoked its messed up
Old 11-03-2003, 02:49 PM
digiman32's Avatar
digiman32 digiman32 is offline
Send a message via AIM to digiman32 Send a message via Yahoo to digiman32
To All Having Problems With Cutting Out
I have noticed a wierd thing while running my xmod. If you lower the controller while running it tends to want to fade out and studder, but just as soon as you raise the controller back up into a straight up and down position, it runs fine. I know this sounds wierd and all, but I have two xmods and they both do the same thing.
Current Xmod:
Skyline GT-R w/Custom Vinyl Graphics, AWD, Stage 2 - Drag, Bearings , Tires, Wheels, Med/Stiff Springs, 3.0 Toe In, Lights
RSX - AWD, Stage 2 - Drag, Bearings, Med/Stiff Springs, Tires, Wheels, 3.0 Toe In, Lights, 6-Cell Mod
Old 11-03-2003, 11:33 PM
now i am really puzzled..put in old stage 1 motor w/plastic heatsink car still has no range..fresh batts etc doesnt help
Old 11-04-2003, 12:12 AM
corysmith's Avatar
corysmith corysmith is offline
Fred Obando Rox My Sox
Send a message via AIM to corysmith
the radio reciever is likely fried, mine had the same prob, i think it was cause i worked on the car with the bats in it. i took it back with no problems
AIM: CoryRSmith37
2000 Honda Civic,
Stage 2 Drag Motor,
Yellow Front, Blue Rear Springs,
LED Lighting Kit,
AWD Kit,
Hard Treaded Tires,
Metal Bearings,
All at a 30% Discount, OORAH!
Old 11-04-2003, 01:58 PM
War Eagle War Eagle is offline
How did you get the 30% discount?
Old 11-04-2003, 03:02 PM
viperkilla's Avatar
I think that he may work at radioshack.
Why Oh Why - Radio Shack Hoverdown3k ZipZaps SE 6 12-18-2006 04:33 PM
fm radio w/ receiver? murphy3688 XMODS Mods and Projects 9 12-14-2004 04:58 PM
radio shack Bit Char Bloke Bit Char-G Parts and Hop-Ups 5 12-13-2002 06:28 PM
Lets see those Radio Shack tracks! joeNuggetz ZipZaps 5 11-25-2002 03:42 AM
Radio Shack; The joy AND bane of my micro scale existance! Namuna Miscellaneous Discussion 17 10-15-2002 04:15 AM
