Old 02-09-2004, 12:16 PM
Alard Alard is offline
Muzzle flash circuit
Here it is
Old 02-09-2004, 12:46 PM
Namuna's Avatar
Namuna Namuna is offline
Thanks Alard.
...Now I just gotta reacquaint myself with how to read a diagram!
Old 02-09-2004, 02:42 PM
Combat-Digi-Q's Avatar
Combat-Digi-Q Combat-Digi-Q is offline
Combat Digi Q PRO
Send a message via AIM to Combat-Digi-Q
Much thanks Alard. You just made my day. Thanks again, it will be going up on my new new website soon. Once I get it up heh. Thanks if you dont want it up then just say so :-)
Combat Digi Q dedicated
Old 02-09-2004, 11:32 PM
4-D 4-D is offline
so is aney one going 2 hook up one of thes puppies up? caz im not i might of done some other dareing stuff 2 my tanks but i can onley go so fare
i might do it if i hade a pic of where evreything goes
Old 02-10-2004, 03:50 PM
zipzapper2 zipzapper2 is offline
Send a message via AIM to zipzapper2
Well this is Combat-Digi-Q under a friends name cuz his stupid thing wont let him log out. I already started hooking up the 555 timer and all the other goodies but ran out of time, I should be able to test it on the tank tomorrow and tell you guys how it is. Il let you guys know how it is.
if it doesn't work hit it harder
Old 02-10-2004, 04:44 PM
marc12 marc12 is offline
that site is going ton be a good one
back on subject,
cool diagram, im going to look at it more thoe
bits,1/10,TTT,1/18
Old 02-10-2004, 08:40 PM
4-D 4-D is offline
fascinating zip or whoever u r.id love 2 see it or hear about it
Old 02-11-2004, 08:06 AM
Use a low power CMOS 555
Glad you are going to try it out. Be sure to use a low power CMOS 555. The ones I use are designated 7555. I don't think the 5 volt supply of the tank will like a standard 555, too much current draw.
Old 02-12-2004, 06:46 PM
Combat Digi Q PRO
Hi alard, I got the circuit build and it didnt work, talked to my digital electronics teacher and he said that 2 of the pins should be swapped. I forget exactly what he said but im gonna test out the new design tomorrow:-)
Old 02-13-2004, 09:33 AM
Aarghh!
Sorry. Don't know how that happened, but, the schematic is wrong. The IR LED low side should be connected to pin 2 of the 555, not pin 4.
I'll post a new schematic.
How do I get the old one removed?
Old 02-13-2004, 09:49 AM
corrected circuit diagram
Musta screwed it up going from Orcad, to Visio, to GIF.
Old 02-15-2004, 06:39 PM
Combat Digi Q PRO
Thx alard, Im on vacation right now so I cant update my circuit right now, but next monday I will be testing the new design out in the tank, Im probly going to use a tick size 555 timer because quite frankly theres not all that much room in these tanks, I might make a couple of these circuits like 20 of em if anybody would be interested in them, Maybe 5 dollars for 1 of em. Dunno yet
Old 02-16-2004, 12:46 AM
spad spad is offline
I might be interested... I got 4 turret tanks coming from Japan this week, with sound tower and 4 tank charger. I've also reactivate my airbrush and diorama kits so i can do big battle on realistic terrain...
i'll post picts soon...
Old 02-16-2004, 01:55 AM
Combat Digi Q PRO
Sounds cool, you have aim, Its alot easier to talk that way! To give you a little more information on the pcb board here it is, The board will be about .5 inches by .25 inches, the board itself will be located in the tank chassis(in the front by the switch) There will be jumper wires to run up to the turret from which a bright white led will send a surge of light through the fiber optics in the barrel, this will inturn make a flash out of the muzzle. The only thing is you will be needing to drill out the barrel of your digi q tanks, that will be a very hard task. Fortunatly I will be selling custom made aluminum barrels that will be almost identical to the plastic ones but will have the drilled out barrel and muzzle. They will come unpainted! Well its 2 am here so ill talk more later
Old 02-16-2004, 01:40 PM
Draconious Draconious is offline
Send a message via AIM to Draconious
If you are replacing the barell any way... why not just replace it with hard, clear plastic tube? paint the outside of it, and leave the end "clear"... and use heat shrink on it, for "thicker" areas if you must... build it up...
Make your own custom light circuit M pro XMODS Mods and Projects 0 03-17-2005 12:07 PM
Muzzle flash Alard Combat Digi Q 7 01-02-2004 02:28 AM
Looking for cheap Mini-Z circuit board... SuperPede1 Mini-Z - Mini-ZRacer.com 4 12-03-2003 03:51 AM
LED Mod - Flash to pass (Get your minds out of the gutter). X_I_Ted Bit Char-G Mods and Projects 6 07-02-2003 07:03 PM
