Old 06-26-2003, 08:47 AM
X_I_Ted X_I_Ted is offline
LED Mod - Flash to pass (Get your minds out of the gutter).
I was looking at the fusebox for my Mustang Convertible one day, and I noticed that there was a fuse for a "Flash to Pass". I had no idea what this was until a week later when I was driving at night and I atttempted to pass a car. As soon as I stomped on the gas, my headlights almost doubled in intensity. When I eased up on the acceleration, my lights returned to normal.
With all of these LED mods on all these bits, it occured to me that with a booster bit you could almost accomplish the same thing. I really haven't thought of the electrical end all that much but it would most likely entail either wiring the LEDs to the bit battery itself, or adding another button cell and a switch that's powered by the boosted function. The effect would be the same. Your LEDs would noticeably brighten whenever you press the booster button.
One caveat is the fact that I'm not sure of anyone who actually stays in the unboosted mode for very long, unless you're out cruising with the other bitpimps in unofficial bit street racing.
This idea isn't meant for racing, but there is no goal too high when pimping out your ride.
A pirate walks into a bar and the bartender exclaims, "You've got a steering wheel on your crotch!"
The pirate replies, "Arrr, it's driving me nuts."
Old 06-27-2003, 07:40 PM
DraGula's Avatar
DraGula DraGula is offline
TinyRC fool!
as far as i know boosting doesnt increase the voltage sent to the motor.
I command you to: check out the site
Old 06-27-2003, 07:45 PM
AUDI-TT's Avatar
AUDI-TT AUDI-TT is offline
XMOD AUDI TT (my wish)
some guy tested it
and boosted its like 1.2-1.3 volts and unboosted its like 0.9 volts
Old 06-29-2003, 11:17 AM
DraGula's Avatar
TinyRC fool!
youd have to wire it to the motor contacts or where the motor wires go on the pcb
Old 06-30-2003, 12:23 AM
crweedon crweedon is offline
you'd have to use some kind of relay, becuase led's usually take about 2-3 volts unless you get the ultra minature pc board mounted ones which would be near impossible to mount/work with. and the exisiting battery does not put out enough for the led's and if you do a battery mod, there still that whole path of least resistance ting you gotta worry about. (damn lazy electricity)!!
Old 06-30-2003, 01:14 AM
If any of you were serious about actually implementing this mod, go and have a look at PH2T's post using a voltage multiplier to power his SMD LED's over at http://www.tinyrc.com/forums/showthr...threadid=11485
After boosting the voltage, you'd still have to find yourself a micro relay and cram it all into your shell.
Old 07-02-2003, 06:03 PM
ph2t's Avatar
ph2t ph2t is offline
Chief Propeller Head
Thanks for the hookup homie. For DCDC convertor stuff you should also check out the "new daul cell" thread in bit science.
Check it HERE .
ph2t.
Best Lightest LED MOD! scottyboyfun Bit Char-G / MicroSizers 9 01-07-2003 01:40 PM
Led Mod Problems pakiplaya Bit Char-G / MicroSizers 1 12-18-2002 05:31 PM
Simple LED mod pakiplaya Bit Char-G / MicroSizers 1 12-16-2002 07:22 PM
Assistance with LED MOD please help a newbie SmokenRubber Bit Char-G / MicroSizers 0 12-04-2002 04:02 AM
