Old 12-15-2003, 12:11 PM
Alard Alard is offline
Muzzle flash
In case anyone is interested.
I have a design for an LED muzzle flash circuit.
The circuit uses a cmos 555 timer, one capacitor, two resistors, one LED. Mounting is somewhat of a challenge.
If you are interested, the circuit will be posted.
Old 12-15-2003, 04:19 PM
Combat-Digi-Q's Avatar
Combat-Digi-Q Combat-Digi-Q is offline
Combat Digi Q PRO
Send a message via AIM to Combat-Digi-Q
YAY! Thx alard, I will be very interested!
Old 12-16-2003, 12:11 PM
Namuna's Avatar
Namuna Namuna is offline
Hulk smash!
Did you even have to ask?! BRING IT ON!
Old 12-19-2003, 12:25 PM
Muzzle flash
It will take a while before I have time to make a diagram.
If you know something about electronics, you could look at a 555 data sheet.
Set up the 555 as a one-shot. Be sure to use a low power cmos part. The negative trigger pin is attached to the low side of the tank IR transmitter LED (the cannon).
+5V and ground are available at the IR receiver pins in the turret.
Quite simple if you have the technical knowledge. If not, then you shouldn't attempt it.
Will post the values for the cap and resistors later. Don't have the circuit in front of me right now.
Old 12-20-2003, 12:04 AM
Napalm_Guru's Avatar
Napalm_Guru Napalm_Guru is offline
Wanna Drag??
Great Alard! don't rush yourself.
Ps: Did you see my post a while back in Meltdowns Thread, My thinking sounds similar.
"Going to war without France is like going deer hunting without an accordion. You just leave a lot of useless noisy baggage behind.
-Jed Babbin
Old 12-29-2003, 02:51 PM
Combat Digi Q PRO
Yo alard... Any updates?!?!?!? Dont leave us hangin man:-)
Old 12-30-2003, 06:51 AM
sorry for delays
Just don't have the time right now, got to draw the schematic
as soon as I get a few minutes.
Old 01-02-2004, 01:28 AM
Tony A Tony A is offline
Muzzle Flash
Someone talked of this last year...he drilled a hole down the barrel, then used a nylon guitar string pushed down the barrel to transfer light from led/whatever, mounted inside the tank to the end of the barrel..I had suggested fibre optic, but he reckoned guitar string worked better...you could probably use a couple of different colours to get a better effect...sound any good?
zipzaps flash game 8ate8 Bit Char-G / MicroSizers 8 12-19-2004 03:09 PM
BIG news flash!!!!! cyrc Miscellaneous Discussion 10 08-02-2004 01:57 AM
Muzzle flash circuit Alard Combat Digi Q 27 02-25-2004 05:46 PM
night fighting 4-D Combat Digi Q 14 02-02-2004 05:15 AM
LED Mod - Flash to pass (Get your minds out of the gutter). X_I_Ted Bit Char-G Mods and Projects 6 07-02-2003 06:03 PM
