Old 07-07-2003, 04:36 PM
Queso's Avatar
Queso Queso is offline
tiny rc racer
soldering questions
Hey all I'm getting ready to do a dual cell mod
on one of my zaps, and was worried about
soldering directly to the battery.
I've got a couple of 1.3 150mah batterys
coming in the mail and didn't want to wreck them.
Any tips or insight would be mosthelpful
"If I had a bike it would have mad pedals"
Old 07-07-2003, 07:11 PM
SupraFreak00 SupraFreak00 is offline
Send a message via AIM to SupraFreak00 Send a message via Yahoo to SupraFreak00
i don't see why soldering to the bat would be bad... but im tring the same.i would also want to learn.
Old 07-07-2003, 08:09 PM
Steve's Avatar
Steve Steve is offline
zipped up tight!
Heat kills batteries. If you hold the gun on the battery too long, she's toast. Problem is, you need heat to make the solder stick. Oh the quandry! And cooking one is easy to do as it's pretty hard to get solder to stick to the bare battery. Hopefully the batts you're getting have tabs already soldered on, if not, God help ya. Only advice I have is flux. If that battery ain't clean, nothin's gonna stick.
Old 07-08-2003, 12:31 AM
Queso's Avatar
tiny rc racer
I heard somewhere that you could scrape up the battery
ends w/ sandpaper to make the solder stick better?
Old 07-08-2003, 03:21 AM
ph2t's Avatar
ph2t ph2t is offline
Chief Propeller Head
Queso, do this.
1) Sand/file the battery end/s so they look fresh and "shiny".
2) Using the soldering iron, quickly melt some solder onto the battery contact where you scraped it. This will put a little blob of solder on the contact.
3) Do this for both sides and then let it cool down.
4) Tin the end of the wire by putting some solder on it, do this for both wires.
5) RE-melt the solder on the end of the battery whilst holding the tinned wire to it. You should be able to get a rock solid connection in seconds...
This is a sure fire way of doing it right. It keeps the temp of the batteries low and ensures a solid join.
ph2t.
Old 07-08-2003, 02:28 PM
Queso's Avatar
tiny rc racer
thanks for the tips
I feel almost confident now
that I won't gak it all up
questions questions questions kasper01001 XMODS 12 01-02-2004 04:38 PM
Bit-Dub Conversion questions mcojoc Bit Char-G / MicroSizers 0 09-25-2003 11:49 AM
Questions for Ahh5hit 55_BrOoKs_55 ZipZaps 8 08-25-2003 07:27 PM
Soldering iron accident (serious) Char-g Ace Bit Char-G / MicroSizers 23 07-01-2003 12:45 PM
Many Questions... Philippe74656 Auldey (All) 4 12-03-2002 03:59 PM
