Old 12-28-2003, 08:15 PM
GerG GerG is offline
Thumbs up Problem found but solved
My SE's steering suddenly stopped working so I pulled the pc board up and unscrewed the piece of plastic that is over the suspension springs and I found tons of little gears and a ball of lint so I took out the lint with tweasers and my car went back to its normal steering (crapy) and all was good. Open yours up even if it isnt screwed up to prevent this from happening.
BE CAREFUL! make sure you hold your zz up in the air or you may have trouble putting the parts back on or even lose the springs!
Old 12-28-2003, 08:20 PM
Comrade_Boris's Avatar
Confirmed: Lost In Fog
i had a similer problem with my savana, i opened it up but everything was fine, the motor locked up and was stiff as a board....
-Andres
Old 12-29-2003, 10:39 AM
Yea I know my bros SE's steering did the samething. I sure hope they fix the SEs then come out with new zzs that are a lot better. I would return mine but I lost the packageing did the ez se adapter mod and put a speaker wire antenna on. I know Im not going to buy the next ZZ too soon Ill wait a couple months for them to fix the ones that are screwed up.
MAN I HATE THESE THINGS!!!!!!!
sputtering problem with my new zap... Cool Dad ZipZaps 12 06-20-2003 11:05 PM
Found Steering Problem You Should All Look At This!!! Jr08bll Bit Char-G / MicroSizers 28 04-11-2003 11:32 PM
problem solved 2fst4u Bit Char-G / MicroSizers 0 04-03-2003 07:35 PM
stock tire tracton problem solved? slotsurfer Auldey (All) 6 01-19-2003 04:35 PM
AH-HA!!! Solved uneven steering problem! mechanist ZipZaps 8 10-17-2002 09:24 PM
