04-09-2003, 05:15 PM
Call me Darth Balls
Found Steering Problem You Should All Look At This!!!
As you guys have probably noticed now I've had steering problems with my r/c. The two most common things you said were "take it apart" or "all of them can't steer right". So at a closer examination of my R/c revealed something. I flipped over my r/c and looked at it with a big magnifying glass and to my surprise found MICROSCOPIC metal pieces smaller than a flea. And I noticed they sat on one side of the front pulling the steering magnet towards them therfore making my car drive only to the left. After several minutes trying to remove them with some tweezers I found my car could properly turn as if it had just came out of the box. I hope this helps those of you who are having a similar problem!
04-10-2003, 12:19 PM
State Property
it's amazin how much little magnetic stuff is realy on the ground!..and we would have never known this if we never bought BITS..is there a mill around where u live?..
04-10-2003, 03:29 PM
Call me Darth Balls
I KNOW AMAZING ISN'T IT! There are a few mills about 10 mi. from my house and my dad works at one of them but its a paper mill
04-10-2003, 03:38 PM
ive posted this a million times.
glue a magnet to the tip of your antenna. you will always have something to suck the metal off(much better than spending all day using tweezers).
no it does not effect range at all in any way
04-10-2003, 03:40 PM
Call me Darth Balls
Or couldn't I just glue a tiny magnet to a pair of tweezers?
04-10-2003, 03:44 PM
you could glue a magnet to anything but you always have a controller in your hand when running your bits so why not put the magnet there so you dont have to carry tweezers around?
04-10-2003, 03:51 PM
they say im slooooow eh?
You could also put a small piece of tape over the bottom of the car, and take it off when there is lots on there.
04-10-2003, 03:54 PM
Call me Darth Balls
That might work. But imagine for those of you with rare earth magnets that must be a B!TCH trying to get off those little shavings
04-10-2003, 03:57 PM
no. you just put the magnetic tipped antenna about 1/4in away from the car and all the stuff just jumps right off. rare earth, ceramic whatever it jumps right off the car.
why would i post a solution over and over if it was bs?
04-10-2003, 04:00 PM
Call me Darth Balls
I never said it was.
04-10-2003, 06:53 PM
speaking of rare earth magnets where do u get them???
carbon fiber, triple deck rear wing : $350.00
"Type R" sticker: $5.00
Stupidity: Priceless
shen qi wei  NX
White Xmod supra 6cell Stage2Drift Light Kit awd
04-10-2003, 06:55 PM
I always wondered.... How does that magnet on the antenna thing work anyway?
04-10-2003, 06:57 PM
Call me Darth Balls
UUUmmm. Online store or radioshack
04-10-2003, 06:58 PM
04-10-2003, 10:46 PM
State Property
i was playin with my Gloria earlier and the steerin was backward!..right was left ect....this is the first time this has ever happend 2 me..i had just replaced the steerin spring..what happend ?
