05-13-2003, 01:49 PM
Tortured Primate
Dropped Spyder
I lowered my eclipse spyder convertable.....as you can see, i cant use the insert with the seats, but i think it looks pretty cool.
Imagination is more important than knowledge...
Albert Einstein
05-13-2003, 01:51 PM
Tortured Primate
top view
top view
Albert Einstein
05-13-2003, 01:52 PM
Tortured Primate
front
Albert Einstein
05-13-2003, 02:04 PM
Great look slam job labs. Easier to see the pics here too. Catch on the other side. Lates....
"When I'm through with you kid, you're gonna piss lightning and crap thunder!"
05-13-2003, 02:33 PM
Acura RSX
WOW!!
I really like it. I was thinking of dropping the sypder too because it sits so high on the chasis. Good job
05-13-2003, 04:00 PM
Tortured Primate
yeah...i liked the body til i put it on the chassis....knew right away i would never use it unsless i dropped it.
Albert Einstein
05-13-2003, 04:22 PM
Nice Work!
Yeah, I will have to do the same thing before I use mine. The S2000 will probably see the same fate as it sits high also.
05-13-2003, 10:22 PM
i like pizza
Hey i was just wondering how you made the new holes for the tab, i was thinking of getting a dremel but if you used something diff i would ty that on some of my "broken" bodies
i will only list the cars that i use once in a while...
ferrari 360 MiniZ; tons of new parts
Integra Type-R Epoch; Stock
Wild CharG; stock, the lifting one
White Skyline microsizer; only factory upgrades, for good handling
05-13-2003, 10:30 PM
Tortured Primate
i used a dremel...get one...well worth the money...thousands of uses...and it's the best tool for modding your zip.
Albert Einstein
05-14-2003, 04:38 AM
There is one cutting blade that is the exact width of the slot that needs to cut, that is what I use.
05-14-2003, 12:07 PM
A little different way to drop the car would be to cut the tabs off of the chassis, take something like an old phone card, etc., cut it into a similar strip and glue that strip onto the chassis at a lower position than the original tab. Personally it just seems to be a little easier than lowering the body.
05-14-2003, 02:28 PM
Tortured Primate
that would work too...only problem with that is any body you use on that chassis would more than likely have to have the wheel wells dremmeled or filed to fit....i guess you could use that chassis for dropped cars only....
Albert Einstein
