Old 03-30-2003, 12:49 PM
pdcr's Avatar
pdcr pdcr is offline
Go speed racer go!
Tri Cell help
I did a dual cell and its FAST AS HELL. But when I put the tri cell it gets as slow as a 1 cell. Any ideas on the problem?
Old 03-30-2003, 01:03 PM
AUDI-TT's Avatar
AUDI-TT AUDI-TT is offline
XMOD AUDI TT (my wish)
i have the same problem!!!!
HEELPP USS
okay first i did a duall cell, then i was tired of it so i redid it into just a stock bit, but now its soooo freakin slow, so i decided to do a triple cell, after i was done the triple cell was as freakin slow as the stock cell??? wtf
did i fry something on the pcb with the duall cell?
Old 03-30-2003, 01:30 PM
bdebde's Avatar
bdebde bdebde is offline
That's all folks
How do you have it wired? Make sure none of the batteries ends are touching the charge contacts (if all in chassis). Make sure that the battery in the battery holder has only one end touching a charge contact. I solder mine together from the battery in the holder (-) to next bat (+), that bat (-) to next bat (+), that bat (-) to negative charge contact (on drivers side of car). I use electrical tape on one end of each battery, the two in the front of the chassis I tape the back ends ( towards charge contact) wit two layers of tape. I tape the battery in the holder on the negative end with three layers of tape. I also put another layer of tape across the top of the positive charge terminal, to prevent anything on the pcb from touching (I had one completely melt on me from this little detail). Make sure the solder points on the pcb do not touch any batteries or contacts in the chassis. Also, if you get batteries too hot while soldering, they will fry. Check each battery by itself if you can, I use an old chassis with a motor wired to charge contacts (kit racer chassis), I can even leave the batteries soldered together if the solder joints are not too big. You want to check that each bat will charge and then run a motor for a while. If bats wont charge or only run the motor for several second, then the bat is likely fried. Hope this helps, good luck.
Also I have found that some motors suck with three cells, you may try a few different motors first. The fastest motor I have in single cell cars is a serious dog in three cell cars.
That's all folks!
Old 03-30-2003, 02:02 PM
pdcr's Avatar
Go speed racer go!
Thanks for your help. I'm gonna try to get the motor first. Then if that doesnt work I'll do what u told me to.
Old 03-30-2003, 09:28 PM
rallger's Avatar
rallger rallger is offline
switcher
Send a message via AIM to rallger
just curious is it stock pcb?
what if the hokey pokey really is what its all about?
Old 03-31-2003, 12:39 PM
SlowbutCourious's Avatar
State Property
..the only luck i had with a 3 cell was buyin 3 watch batt...only lasted for 6 days...but talk about speed...
Old 03-31-2003, 05:38 PM
pdcr's Avatar
Go speed racer go!
I took the X Men car PCB
Gold Honda Civic Zip Zap:
